-1
I went for an interview in BARC India for scientist position. They asked me to draw short transmission line. Then they started asking
What does inductance represent? I said leakage while transmission
Then they said how we can decrease it? I said keep a series capacitor in series.
Then they asked why we can't make it 0? It will be good that power transfer capability increases
Why we don't do that? Here I got confused. Please someone clarify this concept.
My question is that
What will happen if we use a zero inductance line for AC transmission?
What problems it might face?
  • \$\begingroup\$ Did you learn anything in class? if so , what is Inductance ??? If you cannot anwswer this you should go back and learn properly. \$\endgroup\$ Jun 10, 2018 at 12:21
  • \$\begingroup\$ Since, the current is alternating so there is rate of change of current. So we are getting inductance property for transmission line when there is an AC current. \$\endgroup\$ Jun 10, 2018 at 12:27
    \$\begingroup\$ Poor answer. You must master the basics. What is L? what is \$\mu\$ ? What physical ratios affect effective L? \$\endgroup\$ Jun 10, 2018 at 12:29
  • \$\begingroup\$ Sir I will work on it. I am preparing for an interview. So, please can you help me with the question. \$\endgroup\$ Jun 10, 2018 at 12:31
  • \$\begingroup\$ Sorry sir if I am sounding as not wiilling to learn kind of guy. But I have interviews going on for job. The teaching condition here in India is not very good. I have learned more from this website than from my teachers at college. Also I am from one of the top colleges in India but the condition is very bad. \$\endgroup\$ Jun 10, 2018 at 12:44
The short transmission line model is a specific model in transmission line theory that is simplified and does not include shunt capacitance (-jX) as it does in the medium line model. Nor does it include the shunt admittance as it does in the long line model.
Its only impedance is Z = R + jX where X is positive because it is an inductance. (See first sketch in diagram, this is what you should have drawn. Vs is sending voltage and Vr is receiving voltage, so we have a frame of reference of this line.)
Short TX Line Model
Short Answer:
Inductance in this model relates to the transmission line's capacity to move real and reactive power across the line.
Long Answer:
The second sketch shows a phasor diagram for a lagging power factor (theta) system state, meaning the voltage sinusoid (Vr) leads the current sinusoid (I) if those phasors are moving CCW. When the inductor is added, we see a phase shift from Vr to Vs, which we call the power angle (delta).
The transmission line will move maximum Real Power (P = I^2 * R) across the line when the power angle is greatest, meaning Vr and Vs are 90 degrees out of phase. As shown by the phasor diagram, the jIX portion of the Vs vector sum (due to the inductance) will increase this phase difference.
The transmission line will move Reactive Power (P = I^2 * X) across the line when Vs has a greater voltage potential difference than Vr (per unit). The reactive power flows directionally from higher voltage to the lower voltage (per unit). As shown by the phasor diagram, the IR portion of the Vs vector sum (due to the resistance) will increase this voltage difference.
However, our terms of sending and receiving are in fact arbitrary to the frame of reference. If Vr has a greater voltage than Vs, reactive power will flow out from Vr. We will simply choose to describe the power flow as negative reactive power, since power would flow into Vs, contrary to its name V(sending).
The most important thing to note is that these simplified concepts allow us to understand how we can control the magnitude and direction of real and reactive power flow in an electrical grid system.
An inductance in the transmission line only affects the amount of reactive power drawn from the grid. Hence, when there's more inductive load, to make sure the grid voltage remains around ~rms 220V, capacitor needs to be installed at the power supply or anywhere in the grid. The capacitor will be across the powerline and ground. You can think of it as a reactive power source which supplies the requirements of the reactive power required by inductive load.
