For some background, we recently took a product to the EMI lab for EMI Pre-compliance testing and came close to passing, but we have some issues in the 30 to 100MHz range that just put us out of compliance. Unfortunately, as a small shop, we have been unable to see the same noise source in near field testing with our meters and probes, making it guesswork to try and resolve the issue.
We attempted to create a biconical antenna and it is picking up an amplified version of the noise that our probes see, but not the noise seen in the test lab. We have a 100MHz scope with FFT capability and a 1-3300 MHz spectrum analyser, but are still blind.
Is anyone able to offer suggestions on approaches that we might take or something we could build, in order to get that view of the noise that is eluding us?
The product has several cables which are the likely cause, but without some means to see the noise and then try to reduce it, we are stuck going to the test lab which is very pricey.
The following are the results of the test from the test lab. We are trying to get Class A certification but ensure some margin:
EMC Compliance Results
The test is the FCC 30MHz to 1GHz test for emissions.
The following is the spectrum analyzer output from our cobbled antenna at a distance of about 1-2 meters from the device, as shown in the subsequent image.
Spectrum analyser output
The device shown is a surrogate, as we don't wish to publish the product image just yet.
physical test configuration
This next image is our oscilloscope and probe. The spectrum is pretty much the floor baseline at every point except above the power supply, where it is slightly raised but at a different frequency than what is seen in the official EMI lab.
Oscilloscope with FFT enabled and probe
We are using the following spectrum analyser, which worked well for us in reducing some spikes caused by the CPU and harmonics and helped get us to this point.
http://rfinstruments.com/SA0314.html
The antenna was roughly based on information from the following links without the machining involved:
http://everyspec.com/MIL-STD/MIL-STD-0300-0499/MIL-STD-461A_8679/
https://www.eevblog.com/forum/testgear/howto-calibrate-diy-emc-pre-compliance-antenna/
We could not find a plan for an antenna that was suited exactly for our frequency, so we hoped it might work despite the antenna factors not being a good match. We observed the WiFi quite clearly, but lack a good source in the 1-100MHz range to test against.
Thanks
    \$\begingroup\$ Post pictures of the results and state the test being carried out. \$\endgroup\$
    Jun 11, 2018 at 23:25
    \$\begingroup\$ Everything from your antenna down to your scope and the software you are using for the FFT, is that picture above from the lab or the test? I'd like to see pictures of both. The more information you give us, the better we can help you, I'm not walking around your lab, I can't poke at your stuff, and I can't develop a model of what might be going wrong without a boatload of detailed information. Or I could give you a general question and you would say, "I already knew that" \$\endgroup\$
    – Voltage Spike
    Jun 12, 2018 at 3:34
    \$\begingroup\$ Note that the two plots you show differ in that one is on a log frequency scale. The comb of narrow spikes is probably clock harmonics, should be easy to sort out. Can you switch the DUT off and do a sweep then subtract that sweep from the measured data with the device on. You will probably want to switch off known intentional radiators (WiFi, Cell phones, and such that do TDM are particularly problematic). Sometimes getting a shipping container dropped off in the carpark is helpful for this kind of thing as they are relatively RF tight (Especially if you do something about the door seals). \$\endgroup\$
    – Dan Mills
    Jun 12, 2018 at 17:31
    \$\begingroup\$ @DanMills Understood about the difference in scale format. We didn't convert to log format for our equipment. It doesn't offer log format so we need to do that manually. As for the difference between our device being on or off, the whole problem is that we are not seeing anything noticeable between the two. That is the crux of our problem. When we were developing and making changes to eliminate clock noise, there were discernable spikes at 480MHz (2x the CPU) but the low end (< 100Mhz) is not showing anything. \$\endgroup\$
    – Jason K.
    Jun 12, 2018 at 17:38
    \$\begingroup\$ Low end is usually cable radiation unless the device itself is very large, simply because the wavelength is so long. When you switched it off did you pull the power feed or simply use some built in off button on a device fed by a wallwart switcher? Have you passed the 9k-30MHz conducted emissions testing? LF with no clearly defined spikes is often data busses, LCD panels and suchlike, LF spikes usually speak to switched mode power supply in need of better layout. \$\endgroup\$
    – Dan Mills
    Jun 12, 2018 at 19:59
As far as your RF setup goes, I haven't used a far field antenna( the link you have is cool, I'm going to build one), but I have done some near field antenna testing for EMI pre-compliance, which works semi-well for large noise sources. Right now my limiter is my tek scope (3000 series) and my antennas.
I suspect you are hitting your noise floor with both the SA0314 and the oscilloscope FFT, if the noise floor of the instrument is the greatest source of noise in your setup, then adding an amplifier may help such as the one below.
The problem with an amplifier is not just any old RF amplifier will do, unless you calibrate it (and I'm pretty sure calibration will put you under fire of the FCC, how would you do a radio frequency sweep and keep your power low? In some bands you can't transmit at all)
What you want is an amplifier with a flat pass-band, like the one shown above. The one above will give you 30dB amplification and won't distort your signal too much. (Another option would be to get a cheap RF amp with a non-flat gain and see if that gets you above the noise floor, then you can get the EMI amp)
The second problem is calibration itself, each element of the RF system from the antenna has a gain and a pass-band like the one shown above. The gains all add together in the frequency space, if they have nulls or regions where the gain is much lower then those signals won't be able to be seen (example: if your antenna has a null at 300Mhz and is at -100dB then you won't see that frequency). Even a passband at half of the rest of it will interfere with EMI testing.
At a normal EMI lab each part of the system is characterized and calibrated, so they know exactly how much signal is coming in for each frequency when they are all stacked together.
So you could get the amp but if the antenna or spectrum analyzers gain was drastically different (not flat) then you might have trouble seeing certain frequencies.
I've talked to a few people (and not to be a sales guy, but), if you have a few thousand the way to do EMI testing IMO is from tektronix with their RSA306B and the Signal Vu because you can generate calibration profiles for each part of your system. This is the system I wish to get in the future. However it's pricey at 3k$ for the spectrum analyzer, and at least 1k$ for the software, if you have that kind of money, this option might be the way to go.
As far as you EMI goes, ferrites go a long way to stop cables from radiating and conducted emissions. Whenever I do compliance testing I go with a few (or cables like USB with ferrites built-in) another thing I really like are X2Y capcitors that have low inductance to short out high frequencies.
The best resource (which has already been stated) is Electromagnetic Compatibility Engineering by Henry W Ott for any EMI problem.
  • \$\begingroup\$ That's my two cents, hope some of it helps. The question looks great. \$\endgroup\$
    – Voltage Spike
    Jun 13, 2018 at 6:08
  • \$\begingroup\$ Hitting the noise floor makes a lot of sense for the FFT on the scope so we will skip testing with that. The SA0314 has an LNA that can be turned on/off so we will play with that to see if anything pops. \$\endgroup\$
    – Jason K.
    Jun 13, 2018 at 11:06
-1
@Jason: Lots of good comments and I hope you've made progress. About the Fischer current probe: it's a high-frequency probe that allows you to see the current on a wire(s) that could be causing radiation. Here is a short video: https://www.youtube.com/watch?v=nqpQzOWzlK0
As has been mentioned, the source of your radiation problem is likely from a cable or cables; the current probe would enable you to find these currents and know when you've eliminated or reduced them. My best guess on the price is probably around $1.5-2k, so could be out of your range. However, Ken Wyatt has an article about a DIY probe. I've never built/used them, but it might be worth a try: https://interferencetechnology.com/the-hf-current-probe-theory-and-application/#
A couple of other comments: From the picture of your test setup with the antenna, it looks like the power cord to the laptop is running close to the antenna. This could cause the antenna to pick up whatever noise it's radiating. Run the laptop on battery and get it away from the antenna. Use a longer cable from the antenna to the analyzer input if you can. Even try shutting off the lights in case they're causing radiation.
The FCC EMI test bandwidth used is 120 kHz, so set your analyzer to this value or something close (usually 100 kHz is available). And use "MAX HOLD" so it can catch infrequent events. The test lab uses this and "quasi-peak" readings (specific attack and release times).
Finally, try moving your antenna real close to the product you're testing, just to get a stronger signal and see if you see the same frequencies that were present at the test lab.
Hope this helps and best of luck!
  • \$\begingroup\$ Thanks for the links and suggestions. Will include them in my efforts. \$\endgroup\$
    – Jason K.
    Jun 15, 2018 at 3:54
