I am trying to follow the TI document on NFC antenna matching for the TFR7970A chipset.
http://www.ti.com/lit/an/sloa241b/sloa241b.pdf
I am under linux, and while I could try wine to use the smith chart simulation software, I was wondering if I could use qucs or qucs-s for simulating the matching circuit. (or other software available on linux).
  • \$\begingroup\$ I was able to import the S parameter file exported from my VNA, but I don't know how to use it to mimic the procedure in the above application note. \$\endgroup\$ – Nicolas Goy Jun 12 '18 at 16:06
  • \$\begingroup\$ This sounds like a SW recommendation request in disguise, but my immediate question would be "what's wrong with wine?" If you know a software which solves your problem, why don't you simply try running it? \$\endgroup\$ – Dmitry Grigoryev Jun 18 '18 at 8:08
  • \$\begingroup\$ I'd like to understand the simulation process better, the smith chart simulation the pdf uses seems to handle a lot of things automatically. \$\endgroup\$ – Nicolas Goy Jun 18 '18 at 11:55
