6
I have recently switched to the newly-produced SM32H7 MCUs and I am currently in the process of migrating some of my old code to them (I want to see how they handle some applications that require a bit more speed). The H7s feature a DMA request multiplexer, which was absent in older F7s, F4 or F3s that I used to work with. In the latter models DMA channel mapping was accomplished by entering a correct value to the DMA_x Stream_y control register. For example
DMA2_Stream3->CR |= (0x3 << DMA_SxCR_CHSEL_Pos);
would select the 3rd channel for DM2 Stream3 (in case of F7 MCUs, this would correspond to SPI1 TX DMA request: enter image description here As far as I understand, the DMA stream-to-DMA channel mapping is not "hard-wired" anymore and it can be reconfigured manually in the H7 series. As the manual states, DMAMux1 must be used to route a DMA request line to the DMA channel. Unfortunately, the DMAMUX configuration is described rather poorly in the reference manual. I have not managed to grasp how exactly a DMA stream, a peripheral, and a DMA channel are interconnected via the multiplexer. Below is a snippet of code that should, ideally,
  1. Setup SPI1.
  2. Setup the DMA.
  3. Enable the DMA stream for a SPI TX transfer.
    RCC->AHB4ENR |= RCC_AHB4ENR_GPIOAEN;   // Enable usage of GPIOA
    RCC->APB2ENR |= RCC_APB2ENR_SPI1EN;
    GPIOA->MODER &= ~GPIO_MODER_MODER5;
    GPIOA->MODER |= GPIO_MODER_MODER5_1;   // Alternate function for SPI1 SCK on PA5
    GPIOA->OSPEEDR |= GPIO_OSPEEDER_OSPEEDR5;   // High Speed on PA5
    GPIOA->AFR[0] |= (0x05 << 5 * 4);   // AFRL selected AF5 (SPI1 SCK) for PA5
    GPIOA->MODER &= ~GPIO_MODER_MODER6;
    GPIOA->MODER |= GPIO_MODER_MODER6_1;   // Alternate function for SPI1 MISO on PA6
    GPIOA->OSPEEDR |= GPIO_OSPEEDER_OSPEEDR6;   // High Speed on PA6
    GPIOA->AFR[0] |= (0x05 << 6 * 4);   // AFRL selected AF5 (SPI1 MISO) for PA6
    GPIOA->MODER &= ~GPIO_MODER_MODER7;
    GPIOA->MODER |= GPIO_MODER_MODER7_1;   // Alternate function for SPI1 MOSI on PA7
    GPIOA->OSPEEDR |= GPIO_OSPEEDER_OSPEEDR7;   // High Speed on PA7
    GPIOA->AFR[0] |= (0x05 << 7 * 4);   // AFRL selected AF5 (SPI1 MOSI) for PA7
    GPIOA->MODER &= ~GPIO_MODER_MODER4;
    GPIOA->MODER |= GPIO_MODER_MODER4_1;   // Alternate function for SPI1 NSS on PA7
    GPIOA->OSPEEDR |= GPIO_OSPEEDER_OSPEEDR4;   // High Speed on PA7
    GPIOA->AFR[0] |= (0x05 << 4 * 4);   // AFRL selected AF5 (SPI1 NSS) for PA7
    GPIOA->PUPDR |= GPIO_PUPDR_PUPDR4_0;  // Ensure all pull up pull down resistors are enabled
    GPIOA->PUPDR &= ~GPIO_PUPDR_PUPDR5;   // Ensure all pull up pull down resistors are disabled
    GPIOA->PUPDR &= ~GPIO_PUPDR_PUPDR6;   // Ensure all pull up pull down resistors are disabled
    GPIOA->PUPDR &= ~GPIO_PUPDR_PUPDR7;   // Ensure all pull up pull down resistors are disabled
    SPI1->CFG1 = (1u << SPI_CFG1_MBR_Pos) | // Master baud rate: master clock / 2
                     (7u << SPI_CFG1_CRCSIZE_Pos) | // Length of CRC frame
                     SPI_CFG1_TXDMAEN | SPI_CFG1_RXDMAEN | // Enable RX/TX DMA
                     (7u << SPI_CFG1_FTHLV_Pos) | // FIFO threshold level
                     (7u << SPI_CFG1_DSIZE_Pos) //Number of bits in at single SPI data frame
    SPI1->CFG2 = SPI_CFG2_SSOE | // SS output enable
                 SPI_CFG2_MASTER // SPI Master
    RCC->AHB1ENR |= RCC_AHB1ENR_DMA2EN;   // DMA2 clock enable;
    DMA2_Stream3->CR = 0u;
    DMA2_Stream3->PAR = (uint32_t) &(SPI1->TXDR);
    DMA2_Stream3->M0AR = (uint32_t) &(Data_Buffer[0]);
    DMA2_Stream3->CR |= (1u << DMA_SxCR_DIR_Pos);
    DMA2_Stream3->CR |= DMA_SxCR_MINC;
    DMA2_Stream3->CR |= DMA_SxCR_PL;
    DMA2_Stream3->NDTR = 1000;
    // 5. Use DMAMux1 to route a DMA request line to the DMA channel.
    DMAMUX1_Channel0->CCR  = (37u << DMAMUX_CxCR_DMAREQ_ID_Pos);
    SPI1->CR1 |= SPI_CR1_SPE;
    DMA2_Stream3->CR |= DMA_SxCR_EN;
This code compiles and i can upload it to a STM32H753ZIT6 MCU. The full code additionally has PLL setup, which is not included in the snippet above (PLL initialization works just fine, as I am able to probe the 400 MHz system clock on the MCO pin).
The DMA multiplexer setup is, obliviously, incomplete. I have only selected a proper (at least I think that it is proper) assignment of multiplexer inputs to resources. I am not even sure whether the multiplexer channel is correct (or if their choice is arbitrary in the H7 MCUs).
So my question is - what would be the correct way to setup the DMA multiplexer for the SPI TX transfer? If I can get this MWE running, I will be more or less able to finish migrating the rest of my code.
Thanks in advance.
UPDATE:
So, I've been trying to follow user9403409's advice, but, unfortunately, i was not able to go very far. I still cannot get SPI to work over DMA on the H7 series microcontrollers. Now I can get SPI to work without the DMA on the H7's just fine:
#include "stm32h7xx.h"
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
static void InitializeMCO(void);
static void ConfigureHSI(void);
static void InitializeMasterTxSPI(void);
uint8_t s_TransferBuffer[10];
int main()
    s_TransferBuffer[0] = 0xAA;
    s_TransferBuffer[1] = 0xBB;
    s_TransferBuffer[2] = 0xCC;
    ConfigureHSI();
    InitializeMCO();
    InitializeMasterTxSPI();
    while(1){};
    PWR->CR3 |= PWR_CR3_SCUEN;
    PWR->D3CR |= (PWR_D3CR_VOS_1 | PWR_D3CR_VOS_0);
        while ((PWR->D3CR & PWR_D3CR_VOSRDY) != PWR_D3CR_VOSRDY)
    FLASH->ACR = FLASH_ACR_LATENCY_2WS;
    RCC->CR |= RCC_CR_HSION;
    while ((RCC->CR & RCC_CR_HSIRDY) != RCC_CR_HSIRDY)
    RCC->PLLCKSELR = (4u << RCC_PLLCKSELR_DIVM1_Pos) |
                         (32u << RCC_PLLCKSELR_DIVM2_Pos) |
                         (32u << RCC_PLLCKSELR_DIVM3_Pos) |
                         RCC_PLLCKSELR_PLLSRC_HSI
    RCC->PLLCFGR   =  RCC_PLLCFGR_DIVR1EN |
                      RCC_PLLCFGR_DIVQ1EN |
                      RCC_PLLCFGR_DIVP1EN |
                      (2u << RCC_PLLCFGR_PLL1RGE_Pos)  |
                      (1u << RCC_PLLCFGR_PLL1VCOSEL_Pos)
    RCC->PLL1DIVR = ((2u - 1u) << RCC_PLL1DIVR_R1_Pos) |
        ((2u - 1u) << RCC_PLL1DIVR_Q1_Pos) |
        ((2u - 1u) << RCC_PLL1DIVR_P1_Pos) |
        ((10u - 1u) << RCC_PLL1DIVR_N1_Pos)  // Reducing the clock rate so I can probe it with my slow USB scope
    RCC->D1CFGR = RCC_D1CFGR_D1CPRE_DIV1;
    RCC->D1CFGR = RCC_D1CFGR_HPRE_DIV2 |
                  RCC_D1CFGR_D1PPRE_DIV2;
    RCC->D2CFGR = RCC_D2CFGR_D2PPRE1_DIV2 |
                  RCC_D2CFGR_D2PPRE2_DIV2;
    RCC->D3CFGR = RCC_D3CFGR_D3PPRE_DIV2;
    RCC->CR |= RCC_CR_PLL1ON;
    while (!(RCC->CR & RCC_CR_PLLRDY))
    RCC->CFGR |= (1u << 25);
    RCC->CFGR |= RCC_CFGR_SW_PLL1;
    while (!(RCC->CFGR & RCC_CFGR_SWS_PLL1))
/* Displays MCO on PC9 */
    RCC->CFGR |= RCC_CFGR_MCO2;
        RCC->CFGR |= (15 << 25); // Reducing the output so I can probe it with my slow USB scope
    RCC->AHB4ENR &= ~RCC_AHB4ENR_GPIOCEN;
    RCC->AHB4ENR |= RCC_AHB4ENR_GPIOCEN;
    GPIOC->MODER &= ~GPIO_MODER_MODER9;
    GPIOC->MODER |= GPIO_MODER_MODER9_1;
    GPIOC->OTYPER &= ~GPIO_OTYPER_OT_9;
    GPIOC->PUPDR &= ~GPIO_PUPDR_PUPDR9;
    GPIOC->OSPEEDR &= ~GPIO_OSPEEDER_OSPEEDR9;
    GPIOC->OSPEEDR |= GPIO_OSPEEDER_OSPEEDR9;
    GPIOC->AFR[0] &= ~GPIO_AFRL_AFRL0;
    GPIOA->PUPDR &= ~GPIO_PUPDR_PUPDR4;  // Ensure all pull up pull down resistors are enabled
    SPI1->CR1 = 0;
    SPI1->CFG1 = (3u << SPI_CFG1_MBR_Pos) |
                 //SPI_CFG1_TXDMAEN | // SPI_CFG1_RXDMAEN |
                 SPI_CFG2_MASTER
    SPI1->CR2 |= 3;
    SPI1->CR1 |= SPI_CR1_CSTART;
    for (uint32_t i=0; i<3; i++)
            while ((SPI1->SR & SPI_SR_TXP) != SPI_SR_TXP){};
            *((__IO uint32_t *)&SPI1->TXDR) = *((uint32_t *)&s_TransferBuffer[i]);
The code above essentially does three things:
  1. ConfigureHSI initializes the HSI clock (I've reduced the clock speed to be able to do some probing with a slow USB scope that I currently have on my hands).
  2. InitializeMCO displays the main clock output ( just to be sure that the clock is configured properly).
  3. InitializeMasterTxSPI configures the SPI and sends out a three byte message.
I can definitely see that message being sent out on my scope: enter image description here The time base is 200 ns/div, for reference.
On the other hand, if I try to redo the entire thing via DMA, I don't see any output. This is what my DMA-based SPI code looks like:
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
static void InitializeDMA(void);
int main()
    ConfigureHSI();
    InitializeMCO();
    InitializeDMA();
    while(1){};
/* Initializes the MCU clock */
static void InitializeDMA()
    RCC->AHB2ENR |= (0x7 << 29);  // Enable the SRAM
    RCC->AHB1ENR |= RCC_AHB1ENR_DMA1EN;   // DMA1 clock enable;
    // Set the peripheral and memory addresses:
    DMA1_Stream0->PAR = *((__IO uint32_t *)&SPI1->TXDR);
    DMA1_Stream0->M0AR = *((uint32_t *)&s_TransferBuffer[0]);
    DMA1_Stream0->CR = 0u;
    DMA1_Stream0->CR |= (1u << DMA_SxCR_DIR_Pos); // Memory to peripheral
    DMA1_Stream0->CR |= DMA_SxCR_MINC; // Memory increment mode
    DMA1_Stream0->CR |= (3u << DMA_SxCR_PL_Pos); // Very high priority
    DMA1_Stream0->NDTR = 3; // Number of data
    DMAMUX1_Channel0->CCR  = (38u << DMAMUX_CxCR_DMAREQ_ID_Pos);
    GPIOA->MODER |= GPIO_MODER_MODER4_1;   // Alternate function for SPI1 NSS on PA4
    GPIOA->OSPEEDR |= GPIO_OSPEEDER_OSPEEDR4;   // High Speed on PA4
    GPIOA->AFR[0] |= (0x05 << 4 * 4);   // AFRL selected AF5 (SPI1 NSS) for PA4
    SPI1->CR1 = 0;
                 SPI_CFG2_MASTER
    //SPI1->CR2 |= 3;
    DMA1_Stream0->CR |= DMA_SxCR_EN;
Essentially, it is the same thing, the only differences being that there is a InitializeDMA function and the DMA transfer is initiated via the DMA1_Stream0->CR |= DMA_SxCR_EN command (as was the case in the earlier series of MCU's). So, sadly, I am still unable to start the SPI via DMA on the H7s. Any help would be greatly appreciated.
  • \$\begingroup\$ have you tried using the SPI on the H7 in slave mode with DMA ? I modified your posted example, but it does not work. Best regards Karsten \$\endgroup\$ Apr 4, 2019 at 6:52
  • \$\begingroup\$ Dear Karsten. Try running the code from my own answer answer below. The DMA configuration is really similar to the older STM32 series, with the only difference being that you also need to configure the proper DMAMUX channel according to the reference manual. \$\endgroup\$
    – K.R.
    Apr 18, 2019 at 12:25
  • \$\begingroup\$ One more thing. I've encountered problems with the DMA when heavy optimization (-Ofast) is set for the whole project. The answer is to put __DSB() before enabling the DMA stream (right before the DMA2_Stream4->CR |= DMA_SxCR_EN; line). \$\endgroup\$
    – sx107
    Feb 6 at 11:47
8
So, I've actually managed to get the SPI DMA running. Posting my working code below:
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
const uint8_t aTxBuffer[] = "Simple SPI message";
int main()
    ConfigureHSI();
    InitializeMCO();
    InitializeDMA();
    while (1)
            /* Delay added to distinguish between the SPI messages: */
            while(DMA2_Stream4->NDTR != 0) asm("nop");
            for(uint32_t i=0; i<0xBF; i++) asm("nop");
            //DMA2_Stream4->CR &= ~DMA_SxCR_EN;
            DMA2->HIFCR |= DMA_HIFCR_CTCIF4 | DMA_HIFCR_CHTIF4 | DMA_HIFCR_CTEIF4 | DMA_HIFCR_CDMEIF4 | DMA_HIFCR_CFEIF4;
            //DMA2_Stream4->PAR = (uint32_t) &(SPI1->TXDR);
            DMA2_Stream4->M0AR = (uint32_t ) &(aTxBuffer[0]);
            DMA2_Stream4->NDTR = 0x12;
                         RCC_PLLCKSELR_PLLSRC_HSI;
                       (1u << RCC_PLLCFGR_PLL1VCOSEL_Pos);
    RCC->D1CFGR = RCC_D1CFGR_HPRE_DIV2 | RCC_D1CFGR_D1PPRE_DIV2;
    RCC->D2CFGR = RCC_D2CFGR_D2PPRE1_DIV2 | RCC_D2CFGR_D2PPRE2_DIV2;
    RCC->AHB2ENR |= (RCC_AHB2ENR_D2SRAM1EN | RCC_AHB2ENR_D2SRAM2EN | RCC_AHB2ENR_D2SRAM3EN);   // Enable the SRAM
    DMA2_Stream4->CR = 0;
    DMA2_Stream4->CR |= (1u << DMA_SxCR_DIR_Pos);   // Memory to peripheral
    DMA2_Stream4->CR |= DMA_SxCR_MINC;   // Memory increment mode
    DMA2_Stream4->CR |= (3u << DMA_SxCR_PL_Pos);   // Very high priority
    DMA2_Stream4->NDTR = 0x12; //DMA transfer length
    DMA2_Stream4->CR |= DMA_SxCR_EN; // Enable DMA stream
    DMAMUX1_Channel12->CCR = 0x26;
    GPIOA->PUPDR |=  GPIO_PUPDR_PUPDR4;   // Ensure all pull up pull down resistors are enabled
    SPI1->CR1 = SPI_CR1_SSI;
    SPI1->CFG1 = (2u << SPI_CFG1_MBR_Pos) |
                     (7u << SPI_CFG1_DSIZE_Pos);
    SPI1->CFG2 = SPI_CFG2_SSM | SPI_CFG2_MASTER;
Now the basic functionality of the DMAMUX is not too hard, all things considered. The manual states that:
  • DMAMUX1 channels 0 to 7 are connected to DMA1 channels 0 to 7
  • DMAMUX1 channels 8 to 15 are connected to DMA2 channels 0 to 7
  • DMAMUX2 channels 0 to 7 are connected to BDMA channels 0 to 7
These, along with the assignment of multiplexer inputs to resources tables, are the keys to get DMA running (at least running the same way as in the older series of MCUS). For example, SPI1_TX is on the 38th DMA request MUX input of DMAMUX1 (see table 110 in the reference manual). This means that I can employ either DMA1 or DMA2 (and not BDMA, as it is linked to DMAMUX2). I can choose any stream I want, they only need to follow the rule:
  • DMA1_Stream_x -> DMAMUX1_Channel_x
  • DMA2_Stream_x -> DMAMUX1_Channel_(x+8)
So this is how you essentially link a peripheral to a DMA stream via a particular channel of the DMAMUX.
A couple of thing to note as well:
  • Do not forget to set the SPI_CR1_CSTART bit (this is a new thing for the H7's).
  • Be careful with the SPI->CR2 register. If you write a value to it, the SPI transfer will stop after the predefined number of data transfers has commenced. An infinite loop, as presented in my example, will not work if CR2 is set (we will only get a single full SPI transfer).
While the entire thing seem a bit obvious to me now, I will still say that the information in the reference is somewhat lacking. The DMA operation in the older series manuals was described slightly better (at least in my opinion). For example, I still do not know how (and when) to utilize the remaining functionality of the DMAMUX (like the request generators and whatnot). Also, I am not quite sure how memort-to-memory transfers are implemented (I will probably have to learn that when propertime comes).
I hope this helps anyone who wants to delve deeper into ARM programming.
Cheers.
Your DMAMUX configuration is right, you only need to initialize DMAMUX1_CCR_DMAREQ_ID register.
UPDATE 1: I have succesfully initialized DMA for TIM2 timer:
TIM2 DMA configuration for stm32h7
  • \$\begingroup\$ Could you elaborate on that? Isn't that what the: // 5. Use DMAMux1 to route a DMA request line to the DMA channel. DMAMUX1_Channel0->CCR = (37u << DMAMUX_CxCR_DMAREQ_ID_Pos); line does? \$\endgroup\$
    – K.R.
    Aug 10, 2018 at 15:30
  • \$\begingroup\$ @K.R. yes, it is. DMAMUX doesn't need any additional configuration. If you are initerested you can look on my question with DMA configuration (edit answer) \$\endgroup\$ Aug 10, 2018 at 15:41
  • \$\begingroup\$ OK, i will try to rebuild this project as soon as I can get my hands on the hardware. In the mean time, could you clarify about the SYNC_ID bits in the DMAMUX-CxCR register and request generator register (DMAMUX_RGxCR)? When does one need to use those? Furthermore, how do you "attach" a DMA stream to a particular peripheral? In my example above I chose DMA2_Stream3 and DMAMUX1_Channel0, but there is no piece of code that actually links the two together. \$\endgroup\$
    – K.R.
    Aug 10, 2018 at 16:36
    \$\begingroup\$ @K.R. it's just dmamux1_channel0 hardwired to dma1_stream0, dmamux1_channel8 to dma2_stream0 and so on. I believe they needed to synchronously kickstart more than one dma from one event source. If you will interested in my updated code, poke me with the stick. I will send it to you \$\endgroup\$ Aug 10, 2018 at 16:40
