I've been looking for the proper resources in order to find out what component this is.
The manufacturer wouldn't provide any schematics or technical information.
The inscriptions on it are : KE with an X printed sideways.
Unfortunately, this device (whatever it is) is shorted on one side.
    \$\begingroup\$ Where did the chip come from? It could be helpful if you add a photo of the circuit it was removed from. \$\endgroup\$ Jun 14, 2018 at 16:17
    \$\begingroup\$ I don't see an "X". \$\endgroup\$
    Jun 14, 2018 at 16:35
    \$\begingroup\$ "Thanks for accepting me as a newcomer". I don't see how you can possibly know whether you have been accepted at the time of writing the question. We don't actually accept or reject users, but we do up or down vote posts. Only time will tell how your question was received according to the votes. \$\endgroup\$ Jun 14, 2018 at 17:02
    \$\begingroup\$ "The manufacturer wouldn't provide ANY scematics nor technical info's." What manufacturer? Manufacturer of what? If you know the manufacturer of this part, then you should tell us. \$\endgroup\$ Jun 14, 2018 at 17:03
    \$\begingroup\$ "with an X printed sideways". I don't see any "X" either. Also a "X" printed sideways (rotated 90 deg?) would still look like a X, so how could you tell if it was "sideways"? \$\endgroup\$ Jun 14, 2018 at 18:24
Probably a 2SK3065 60V/2A n-channel MOSFET. SC-62 is another name for SOT-89.
That looks to be a SOT-89 package. Most likely it is some kind of transistor or linear regulator.
This is a unlikely package for a diode. I've seen diodes in SOT-23 packages, but by the time they need to dissipate more power they usually come in SMA packages.
Probe around with a ohmmeter, and maybe you can figure out what kind of transistor this is and which pins are what leads.
    \$\begingroup\$ It could be a voltage regulator as well. \$\endgroup\$ Jun 14, 2018 at 17:49
  • \$\begingroup\$ @Chu: Good point. Added to the answer. \$\endgroup\$ Jun 14, 2018 at 18:21
  • \$\begingroup\$ Unfortunately, this device is shorted on one side. Probing just showed up to be a transistorbetween left and center pin, the right one is shorted with the center one \$\endgroup\$ Jun 15, 2018 at 15:11
