First, let me say that I'm very new to electronics so this issue may just be down to me doing something wrong.
It started when I was trying to test the gain of a PNP transistor. The expected values were 0.016mA for base and 3.1mA for collector. I kept getting 0.03mA for both. My multimeter has 1 terminal for A and another terminal for everything else, including mA (I was using the mA terminal). I assumed I was just doing something wrong but eventually decided to test the multimeter on a simple circuit.
I connected an LED, a 470 ohm resistor and the multimeter in series as a test. With no multimeter, the LED is on. Using the A terminal, the LED is on and has a value of 0.014A. Using the mA terminal, the LED is not on and the reading is 0.03mA.
So my question is: am I just messing this up somehow or is my multimeter broken?
The options I have considered are:
- The multimeter is working and I have just made a mistake somewhere.
- The current in the test circuit with the mA terminal is actually 0.03mA. The low current could be the reason the LED isn't turning on. But why would it work fine using the A terminal?
- The multimeter with the mA terminal is not forming a circuit for some reason. This would explain why the LED won't switch on. However, the multimeter reading does increase from 0 to 0.03mA once the battery is connected, which suggests some current is flowing.
All in all, I'm very confused. I only started this a few days ago so have no idea what I'm doing. I did test the current of the same test circuit yesterday (using the mA terminal) and I didn't notice it giving a really low value, but I wasn't really paying attention.
mA
terminal is fused, so if you measure a current higher than it is rated for, the fuse will burn. \$\endgroup\$
