I would like to have a rough estimate of the capacitance per unit length of a system composed by N parallel identical straight wires. I tried to sketch the capacitance network but I'm able to solve it only up to 4 wires... Any idea how to smplify the problem?
  • \$\begingroup\$ Is the distance far enough that we can approximate the wires as 'flat'? \$\endgroup\$ – Oldfart Jun 16 '18 at 8:35
  • \$\begingroup\$ @Oldfart: if this can help, sure. At this stage I would like just to know the equivalent capacitance; the physical implementation would be a second step, but you are more than welcome to already take this aspect in consideration . \$\endgroup\$ – Andrea Jun 16 '18 at 8:44
  • \$\begingroup\$ Sorry, second question which I should have asked at the same time. The LHS is V, RHS is GND, the middle wires are connected to what? \$\endgroup\$ – Oldfart Jun 16 '18 at 8:48
  • \$\begingroup\$ @Oldfart: still, the whole picture is more complicated than this... If you are interested in the voltage at each point we can say that it is 2V/3 on the first wire, V/3 on the second one. But to solve the capacitance network you don't really need to know all these details right? (I really appreciate your effort) \$\endgroup\$ – Andrea Jun 16 '18 at 8:54
  • \$\begingroup\$ @Oldfart: if you really want you can see the entire system as a meander line \$\endgroup\$ – Andrea Jun 16 '18 at 9:07
It has been a loong time since I did basic electricity and fields.
The simplest representation of a capacitor is two flat electric plate at a distance. There will be an electric field between these plates:
The electric field starts at potential V and, with a constant dielectric, will linear with distance go to 0V (Gnd). This means that in the middle you find a potential of V/2.
If we place a very thin electric plate at 1/3d from V, the potential of the plate will then be 2/3V:
If you would externally set a potential of 2/3 V on that plate the electric field, and thus the capacitance would be the same.
This means that all your wires in the middle do not make a difference and can be ignored.
As you can see, the voltage on those line places a crucial role.
  • \$\begingroup\$ Let us call C1 the capacitance between the first neighbours, C2 the capacitance between the second ones and so one, what is the value of the total capacitanc? Cn? \$\endgroup\$ – Andrea Jun 16 '18 at 10:57
  • \$\begingroup\$ Please see my answer: This means that all your wires in the middle do not make a difference and can be ignored. \$\endgroup\$ – Oldfart Jun 16 '18 at 10:59
  • \$\begingroup\$ sorry but why solving the lumped element circuit Ctot=C3+2(C1C2/(C1+C2))? \$\endgroup\$ – Andrea Jun 16 '18 at 11:04
  • \$\begingroup\$ Sorry, but there is nothing more I can do. For some reason you keep going into a direction which is wrong. There is no lumped capacitance, only the capacitance between the outer wires counts. (As @Andyaka also stated) \$\endgroup\$ – Oldfart Jun 16 '18 at 11:15
  • \$\begingroup\$ does the same (i.e. the field doesn't change) happen even if you substitute the "parallel plate capacitor" approach with wires with circular cross section? \$\endgroup\$ – Andrea Jun 16 '18 at 12:19
