I have an active buzzer connected to an Arduino and everything works fine but the buzzer is just not loud enough. I don't know any specs about the buzzer but I've tried connecting it to a 9v battery using a transistor with the collector connected to +9v, the base connected to the digital output pin of the Arduino, and the emitter connected to the buzzer. This did not seem to do anything different. I tried using a passive buzzer as well using a PWM pin, but I was not able to achieve the same results so I'd like to stick with the active buzzer. Thank you.
\$\begingroup\$ Active buzzers have specs limiting their maximum current and voltage and thus output power. If you want a louder buzzer look into a better hardware. \$\endgroup\$ – nabulator Jun 17 '18 at 4:54
\$\begingroup\$ Try 12V or get specs \$\endgroup\$ – Tony Stewart Sunnyskyguy EE75 Jun 17 '18 at 4:58
\$\begingroup\$ something like this maybe? ... youtube.com/watch?v=8zEH5GxPNO8 \$\endgroup\$ – jsotola Jun 17 '18 at 5:34
\$\begingroup\$ @jsotola I assume that guy lives alone. I would be flayed alive for making something like that. My iPad "old car horn" is bad enough (secondary alarm if the gentle first one doesn't work). \$\endgroup\$ – Spehro Pefhany Jun 17 '18 at 6:01
Put the buzzer in the collector circuit and it should be about as loud as it is connected directly to the 9V source. If that's not loud enough, get another buzzer. Hopefully it's rated to work with 9V.
You were connecting it as an emitter-follower which gives you about 0.7V less than the logic input voltage (4.3V with 5V logic) and the remainder (4.7V with a 9V supply) wasted in the transistor. A higher supply would just result in more wasted power. Depending on how much load the buzzer represents the emitter follower may result in a bit less loud than a direct connection or a bit louder (since the MCU output will be loaded significantly by most buzzers and you won't get the full 5V out).
\$\begingroup\$ @gbarry 4.7 if you have the collector connected to 9V (as OP did). 0.7V if you have the collector connected to 5V. In both cases, the buzzer sees 4.3V. \$\endgroup\$ – Spehro Pefhany Jun 17 '18 at 5:12
\$\begingroup\$ But why the diode? Are buzzers significantly inductive? \$\endgroup\$ – Vladimir Cravero Jun 17 '18 at 9:02
\$\begingroup\$ @VladimirCravero Some of them are magnetic, some are piezo. If magnetic they may not have any bypassing so when they shut off the voltage might spike up. Probably not to the 60V that would begin to threaten a 2N4401 but putting a diode in there causes no harm and is cheap. \$\endgroup\$ – Spehro Pefhany Jun 17 '18 at 12:54
