I'm looking at a 220V-50Hz 3phase generator which has no neutral wire and 3 live wires.
Am I correct in assuming that the voltage between phases will be 220V for this generator?
Am I correct in assuming that the voltage between phases will be 220 V for this generator?
Yes. If there is no neutral then there is nowhere to reference a phase voltage from except one of the other phases.
Note 'V' for volt. 'Hz' for hertz. Units named after a person have their symbols capitalised but are lowercase when spelled out.
| improve this answer | |
