The system is basically three inductors connected to each other in one end and the other end connected to three independent voltage sources. enter image description here
I want to get the equations in state space form. For this I need to eliminate the intermediary variable VT.
I cant figure out how to proceed from here.
  • \$\begingroup\$ So what is your question? \$\endgroup\$
    Jun 18 '18 at 9:34
You need to use Kirchhoff's current law on the node with voltage \$V_T\$: $$ i_1 = i_2 + i_3 $$ Taking the time derivative at both sides results in $$ \frac{\mathrm{d}i_1}{\mathrm{d}t} = \frac{\mathrm{d}i_2}{\mathrm{d}t} + \frac{\mathrm{d}i_3}{\mathrm{d}t} $$ You now have a set of 4 equations in 4 unknowns (\$\frac{\mathrm{d}i_1}{\mathrm{d}t}\$, \$\frac{\mathrm{d}i_2}{\mathrm{d}t}\$, \$\frac{\mathrm{d}i_3}{\mathrm{d}t}\$, and \$V_T\$): $$ \begin{cases} L_1 \frac{\mathrm{d}i_1}{\mathrm{d}t} & = V_T - V_1 \\ L_2 \frac{\mathrm{d}i_2}{\mathrm{d}t} & = V_2 - V_T \\ L_3 \frac{\mathrm{d}i_3}{\mathrm{d}t} & = V_3 - V_T \\ \frac{\mathrm{d}i_1}{\mathrm{d}t} & = \frac{\mathrm{d}i_2}{\mathrm{d}t} + \frac{\mathrm{d}i_3}{\mathrm{d}t} \end{cases} $$
After eliminating \$\frac{\mathrm{d}i_1}{\mathrm{d}t}\$ and \$V_T\$, you get $$ \begin{bmatrix} \frac{\mathrm{d}i_2}{\mathrm{d}t} \\ \frac{\mathrm{d}i_3}{\mathrm{d}t} \end{bmatrix} = \frac{1}{L_1L_2+L_1L_3+L_2L_3} \begin{bmatrix} -L_3 & L_1+L_3 & -L_1 \\ -L_2 & -L_1 & L_1+L_2 \end{bmatrix} \begin{bmatrix} V_1 \\ V_2 \\ V_3 \end{bmatrix} $$ which is a state equation of the form \$\frac{\mathrm{d}x}{\mathrm{d}t}=Ax+Bu\$. The state variables are \$x_1=i_2\$ and \$x_2=i_3\$. The inputs are \$u_1=V_1\$, \$u_2=V_2\$, and \$u_3=V_3\$. The matrix \$A\$ is a zero matrix and the matrix \$B\$ is $$ B = \frac{1}{L_1L_2+L_1L_3+L_2L_3} \begin{bmatrix} -L_3 & L_1+L_3 & -L_1 \\ -L_2 & -L_1 & L_1+L_2 \end{bmatrix} $$
