My country has a problem with the mains electricity supply, which cuts off and comes back straight away. My router restarts every time that happens.
What I like to know is: What would be the most efficient way to have a 5 seconds power supply backup on my router?
  • Router: ASUS RT-N12+
  • Power Supply:
    • AC Input: 110V~240V (50~60Hz)
    • DC Output: 12 V with max. 0.5 A current
A schematic would be amazing since I am totally new to this subject.
    \$\begingroup\$ A 12 V rechargeable battery OK with you? \$\endgroup\$
    – winny
    Jun 18, 2018 at 14:22
  • \$\begingroup\$ for only 5s 12v rechargeable battery might be too much. can i use capacitor? @winny \$\endgroup\$
    – Autobot
    Jun 18, 2018 at 14:29
    \$\begingroup\$ @Autobot The problem with a capacitor is that the voltage starts to drop immediately, and that's quite a large current so you'd need to have a big(!) capacitor at higher voltage and regulate down. 12 V rechargeable is the way to go... \$\endgroup\$
    – awjlogan
    Jun 18, 2018 at 14:35
  • \$\begingroup\$ Depends, are you willing to buy a ~2.5 F, 12+ V capacitor? \$\endgroup\$
    – winny
    Jun 18, 2018 at 14:52
    \$\begingroup\$ @Autobot - FYI I remember that similar questions have been asked several times over the past years. Please make sure that you have searched this site (notice the search box at the very top of this page, next to the words "StackExchange") using different combinations of words like ups, power, backup, router etc. as a previous solution may help you directly, or allow you to narrow the "solution space". For example, I remember that your suggestion to use a capacitor to "bridge" such power outages, has already been discussed (with lots of helpful calculations) in previous questions on this topic. \$\endgroup\$
    – SamGibson
    Jun 18, 2018 at 15:24
Rather than make something, it is probably best to by a mini-UPS such as this for about $25. It is designed specifically for keeping routers powered during power outages. Fits between the router and the router 12V power supply
  • \$\begingroup\$ is it safe to use pass-through charging power bank and use USB DC 5V to DC 12V Step up Cable Module Converter. in my country I can have both at around $15. I looked at my country sites but couldn't find any ups for the router. \$\endgroup\$
    – Autobot
    Jun 18, 2018 at 14:50
  • \$\begingroup\$ @Autobot - Where did 5V DC come from? Why are you using USB? \$\endgroup\$
    – Bort
    Jun 18, 2018 at 19:23
  • \$\begingroup\$ @Bort form powerbank \$\endgroup\$
    – Autobot
    Jun 18, 2018 at 19:42
  • \$\begingroup\$ @Autobot - That doesn't help, you didn't even answer why you are using USB. Where did 5V come into this conversation? You were talking about needing a backup supply for 12V, not 5V. What is 5V for? Am I supposed to understand? \$\endgroup\$
    – Bort
    Jun 18, 2018 at 19:44
  • \$\begingroup\$ @Bort form power bank DC USB output 5V to DC 12V Step-up converter link \$\endgroup\$
    – Autobot
    Jun 18, 2018 at 19:47
