AN ANSWER
My minimization is:
$$\begin{smallmatrix}
\begin{array}{l|l}
\begin{array}{l}
\begin{array}{l}
Z_0 \:=\: \overline{B_3}\: B_1\: B_0\\
Z_1\: =\: B_3\: B_2\: B_1\\
Z_2 \:=\: \overline{B_3}\: B_2\: \overline{B_1} \:B_0\\
Z_3\: =\: \overline{B_3}\: \overline{B_2}\: \overline{B_0}\\
Z_4 \:=\: B_3\: \overline{B_2}\: \overline{B_1}\\
Z_5\: =\: \overline{B_3}\: B_2\: B_1\: \overline{B_0}\\
Z_6\: =\: B_3\: B_2 \:\overline{B_0}\\
Z_7\: =\: B_3\: \overline{B_2}\: \overline{B_0}\\
Z_8\: =\: \overline{B_3}\: \overline{B_1}\: \overline{B_0}\\
Z_9\: =\: \overline{B_3}\: B_2\: \overline{B_0}\\
Z_{10} =\: \overline{B_3}\: \overline{B_2}\: B_1\\
Z_{11} =\: B_3 \:B_2\: \overline{B_1}\: B_0\\
Z_{12} =\: B_3\: \overline{B_2} \:B_1\: B_0\\
Z_{13} =\: \overline{B_2}\: \overline{B_1}
\end{array}
\end{array}
\begin{array}{l}
\begin{align*}
A\: &=\: Z_0 + Z_1 + Z_2 + Z_3 + Z_4 + Z_5 + Z_6 + Z_7\\
B\: &=\: Z_0 + Z_3 + Z_7 + Z_8 + Z_{11} + Z_{13}\\
C\: &=\: Z_0 + Z_2 + Z_5 + Z_7 + Z_8 + Z_{11} + Z_{12} + Z_{13}\\
D\: &= \: Z_2 + Z_3 + Z_4 + Z_5 + Z_6 + Z_{10} + Z_{11} + Z_{12}\\
E\: &= \: Z_1 + Z_3 + Z_5 + Z_6 + Z_7 + Z_{11} + Z_{12}\\
F\: &= \: Z_1 + Z_2 + Z_4 + Z_5 + Z_6 + Z_7 + Z_8 + Z_{12} \\
G\: &= \: Z_1 + Z_2 + Z_4 + Z_9 + Z_{10} + Z_{11} + Z_{12}
\end{align*}
\end{array}
\end{array}
\end{smallmatrix}
A SUGGESTION
I was a little disappointed in the work you put into the question. Partly, because I wasn't sure what you wanted. It has arrived now through a series of comments. But it would be nice if you'd anticipated it, earlier. Partly, because you only provided an image of your handwriting, but no particular clarity about your full table or the active sense of the A-G outputs. Sure, that can be inferred. But, why should we have to?
So in the interest of making the above point, let me add here what I think you might have considered adding to your question before asking it.
Here is a possible table and set of K-maps. I've included a "don't care" where I'm not sure about what you need there.
\begin{array}{cccc|ccccccc}
B_3&B_2&B_1&B_0&A&B&C&D&E&F&G\\
\hline
0&0&0&0&1&1&1&1&1&1& \\
0&0&0&1& &1&1& & & & \\
0&0&1&0&1&1& &1&1& &1\\
0&0&1&1&1&1&1&1& & &1\\
0&1&0&0& &1&1& & &1&1\\
0&1&0&1&1& &1&1& &1&1\\
0&1&1&0&1& &1&1&1&1&1\\
0&1&1&1&1&1&1& & &X&\\
1&0&0&0&1&1&1&1&1&1&1\\
1&0&0&1&1&1&1&X& &1&1\\
1&0&1&0&1&1&1& &1&1&\\
1&0&1&1& & &1&1&1&1&1\\
1&1&0&0&1& & &1&1&1&\\
1&1&0&1& &1&1&1&1& &1\\
1&1&1&0&1& & &1&1&1&1\\
1&1&1&1&1& & & &1&1&1
\end{array}
\end{smallmatrix}$$
K-maps:
\begin{array}{rl}
\begin{smallmatrix}\begin{array}{r|cccc}
A&\overline{B_1}\:\overline{B_0}&\overline{B_1}\: B_0&B_1 \:B_0&B_1 \:\overline{B_0}\\
\hline
\overline{B_3}\:\overline{B_2}&1&0&1&1\\
\overline{B_3}\:B_2&0&1&1&1\\
B_3\: B_2&1&0&1&1\\
B_3\:\overline{B_2}&1&1&0&1
\end{array}\end{smallmatrix}
B&\overline{B_1}\:\overline{B_0}&\overline{B_1}\: B_0&B_1\: B_0&B_1 \:\overline{B_0}\\
\hline
\overline{B_3}\:\overline{B_2}&1&1&1&1\\
\overline{B_3}\:B_2&1&0&1&0\\
B_3\: B_2&0&1&0&0\\
\end{array}\end{smallmatrix}\\\\
C&\overline{B_1}\:\overline{B_0}&\overline{B_1}\: B_0&B_1\: B_0&B_1 \:\overline{B_0}\\
\hline
\overline{B_3\:}\overline{B_2}&1&1&1&0\\
\overline{B_3}\:B_2&1&1&1&1\\
B_3\: B_2&0&1&0&0\\
B_3\:\overline{B_2}&1&1&1&1
D&\overline{B_1}\:\overline{B_0}&\overline{B_1}\: B_0&B_1\: B_0&B_1\: \overline{B_0}\\
\hline
\overline{B_3}\:B_2&0&1&0&1\\
B_3\: B_2&1&1&0&1\\
B_3\:\overline{B_2}&1&X&1&0
E&\overline{B_1}\:\overline{B_0}&\overline{B_1}\: B_0&B_1\: B_0&B_1\: \overline{B_0}\\
\hline
\overline{B_3}\:\overline{B_2}&1&0&0&1\\
\overline{B_3}\:B_2&0&0&0&1\\
B_3\: B_2&1&1&1&1\\
B_3\:\overline{B_2}&1&0&1&1
F&\overline{B_1}\:\overline{B_0}&\overline{B_1}\: B_0&B_1\: B_0&B_1\: \overline{B_0}\\
\hline
\overline{B_3}\:\overline{B_2}&1&0&0&0\\
\overline{B_3}\:B_2&1&1&X&1\\
B_3\: B_2&1&0&1&1\\
G&\overline{B_1}\:\overline{B_0}&\overline{B_1}\: B_0&B_1\: B_0&B_1\: \overline{B_0}\\
\hline
\overline{B_3}\:\overline{B_2}&0&0&1&1\\
\overline{B_3}\:B_2&1&1&0&1\\
B_3\: B_2&0&1&1&1\\
\end{array}
Had you provided these, or something similar, your question would have been greatly improved. And it would have saved me time I should not have had to spend on your behalf.
I know you meant well. And I'm not meaning to be overly-critical. I'm just suggesting that saving the time of others is basic consideration, good etiquette, and perhaps even a moral duty. One should put all necessary time into the question, even adding things felt to be almost unnecessary details. Because if it saves just a few minutes of time for others it is very much worth doing.
As it is, I've had to add this in order to set the context needed to make my own answer clearer.
APPROACH
For now, I'm holding short. Because of the price I already paid in laying out the above, I'll have to come back to this when I'm back in the mood and have the available time to dive in, again. For now, perhaps you can look over the tables and see if I made any mistakes. Also, see if the answer at the top appears to achieve the goal.
In the meantime, perhaps you can also consider reading An Algorithm for Multiple Output Minimization, by Gurunath and Biswas, 1989.
edit
button to do that now. Have you minimized your equations? Are you treating each segment as an independent problem, or do you believe you've found some overlap of pattern that is worth leveraging? \$\endgroup\$
