I have several 18650 Li-Ion batteries, many with different capacities. Can I charge them with the same charging circuit (5 to 3.7 V 1 A buck converter)? Can I put them in parallel and use the same step up circuit to make a 5 V USB bank?
  • \$\begingroup\$ Have you done any research on this yet? \$\endgroup\$
    – Bort
    Jun 19, 2018 at 17:30
  • \$\begingroup\$ I have tried, but I can't really find anything on this. Most of the time its just about one type of battery, and when it isn't, its about different chemestries, or ages of batterys. \$\endgroup\$ Jun 19, 2018 at 17:32
  • \$\begingroup\$ You shouldn't be using just a buck converter to charge Li-Ion batteries, and 3.7V 'nominal' batteries are seldom (if ever) charged at 3.7V (4.1V or so would be more common). Are you using a charge controller? \$\endgroup\$
    – brhans
    Jun 19, 2018 at 17:40
  • \$\begingroup\$ Yeah, I was just going to buy a 18650 charger off of ebay or something \$\endgroup\$ Jun 19, 2018 at 17:52
  • \$\begingroup\$ Should be fine if you can balance their voltages first. \$\endgroup\$
    – winny
    Jun 19, 2018 at 18:10
If you mean to charge each cell individually, then it should be fine, provided that the charger doesn't exceed max charging current for the smaller cell. But if you mean to make a battery out of two different cell in parallel, and charge-discharge them as a battery, then the following apply:
One should never charge different Li-Ion batteries in parallel. It is true even if the cells are of the same rating, but their charge-discharge characterics do not match to high (1-2%) degree. Charging cells in parallel is unacceptable for three reasons:
  1. Li-Ion cells with different capacity will take different time because a smaller-capacity cell will/might be charged first, and then will be overexposed to charging voltage (while the bigger cell still gets the charge). This will result in "overcharging" of the weaker cell, it will grow some bad chemistry inside, its capacity will fall more, and it will die being bloated or worse.
  2. On discharge cycle the process is also bad - weaker (less capacity) cell might be depleted first, and fall into "overdischarged" state, with similar bad implication for internal chemistry.
  3. On charge, a stronger cell with less internal impedance might take more current than the cell design can afford, which can lead to "fast venting including fire".
In short, it is a very bad idea to make a battery from different Li-Ion cells in parallel without either perfect matching, or using some electronics to manage each cell individually.
  • \$\begingroup\$ If they are in parallel, the voltage across must be the same. So, for #1: how would the smaller capacity cell be charged sooner? During charging, 3.5V is 3.5V. One cell cannot reach a higher level than another. #2: same as #1. How can either be more depleted, percentage wise? Perhaps only if the state of health had changed significantly. #3: Agreed, though it can be accounted for. \$\endgroup\$
    – Bort
    Jun 22, 2018 at 16:53
  • \$\begingroup\$ @Bort, Li-Ion chemistry gets its predominant charge during constant-current phase. The voltage is creeping up slowly during the process. When the internal chemistry gets charged to certain degree, the cell starts to consume less and less current, which is a precursor to end the charge. First, no one can guess how the input current will be split between two cells (#3), then a smaller cell will/might charge faster, its current will drop, while the other is still charging (#1) and consuming current (so the charger won't stop) thus overexposing the smaller cell. \$\endgroup\$ Jun 22, 2018 at 18:41
  • \$\begingroup\$ It sounds like the only issue is overcurrent (and not voltage), would you agree? If, say, the paralleled cells are charged by a 1A charger, and 1A is not above the max for any individual cell, then there is no issue with current, yes? For discharge, I am assuming the draw is also managed to be less than any particular cell's max. No offense, but I am still doubting your #1 and #2. I have been told be colleges in the Li-ion field that there are battery packs used in consumer products, such as macbooks, that actually use batteries in parallel. (I have to verify that.) \$\endgroup\$
    – Bort
    Jun 22, 2018 at 21:21
  • \$\begingroup\$ @Bort, the voltage was never an issue, assuming identical cell chemistries. In almost all cases (before proliferation of small tablets and smartphones) all laptop batteries were made in mixed configuration, 2P or 3P (in parallel), and 3S (11.1V). But all cells in the parallel sections are carefully selected/matched by manufacturers with nearly identical characteristics. \$\endgroup\$ Jun 22, 2018 at 21:53
    \$\begingroup\$ This answer is flat out wrong. \$\endgroup\$
    – Drew
    Aug 26, 2019 at 7:28
Ale's answer to this is incorrect.
If one cell were to be a higher voltage than another, current would flow from that cell to the lower cell. The impedance of the cells is quite low so the voltages are effectively locked together. Therefore overcharging a cell is not a risk.
Discharging works the same way. At reasonable rates of discharge like 1C, the cell voltages will continue to be locked together. You can't over-discharge a cell, because if that were to happen current would start flowing into it from the other cells. In practice it will never even get into this state.
At extremely high rates of discharge (we're talking 10's of amps here), the ESR mismatch of the batteries may cause them to go out of balance. If at any time the load is removed though, the batteries will start to re-balance as current flows from the high cell to the low cell. This is only really relevant in RC and similar high stress applications where a pack might be discharged in under 2 minutes.
If a cell has less impedance and charges faster it's voltage will go up infinitesimally, this will cause it to take less current. At low rates of charge, the cells will naturally distribute current in proportion to their capacity. One caveat is that if a wire breaks, the current will be redistributed to the other cells, potentially exceeding their charging limits.
Disclaimer: the preceding only applies to single cells with varying capacity in parallel. With series cells its more complicated.
Lipos can be dangerous. This is all theoretical so please take it with a grain of salt. I'm posting it anyway because Ale's answer is misinformative, even if it is well intentioned.
  • \$\begingroup\$ "so the voltages are effectively locked together. Therefore overcharging a cell is not risk." - you probably need to check with other sources for the meaning of "overcharging of Li-Ion cell". Two kinds of overcharge are usually considered, "overcharge" due to too high charging current (and associated thermal effects), and degradation of electrolyte due to prolonged exposure to charging voltage (constant voltage!!!). In no case people consider overcharge as "overvoltage", Please start with layman articles such as batteryuniversity.com/learn/article/… \$\endgroup\$ Aug 27, 2019 at 4:52
  • \$\begingroup\$ However, I might agree with your point about overdischarging. And my third point about uneven current distribution might be questionable, the current split depends on particularities of cell design (high-discharge lower capacity cell may have lower ESR and consume higher charge). However, my first point about overcharging (in the sense of overexposing a cell to charging voltage) is absolutely valid. Please read comments to my answer. \$\endgroup\$ Aug 27, 2019 at 5:18
  • \$\begingroup\$ During proper charging a lipo will not be exposed to voltages in excess of the full cell voltage. A fully charged cell has no way to "know" the charger is even there, since no current will flow into it, just as none would flow if there was an open circuit. \$\endgroup\$
    – Drew
    Aug 27, 2019 at 5:34
  • \$\begingroup\$ "A fully charged cell has no way to "know" the charger is even there" - not true. Read the literature. From cited Battery University: Li-ion cannot absorb overcharge. When fully charged, the charge current must be cut off. A continuous trickle charge would cause plating of metallic lithium and compromise safety. \$\endgroup\$ Aug 27, 2019 at 22:06
    \$\begingroup\$ Just throwing my hat in the ring here for those to view this later. Ale's answer is unequivocally wrong, and Drew's is right. The other things to consider are the thermals. In high C rate applications, the lower impedance cells will generate more heat as they do more work. \$\endgroup\$
    – Nino
    Mar 5, 2021 at 3:08
