I ordered some MOSFET switch modules. Because they were advertised as "for Arduino" and "Voltage: 3.3V, 5V", I assumed they had chosen a decent MOSFET for the job (like the IRLU7843 or at least the IRLZ34N). There is no additional circuitry on the modules.
Now I see that they use the IRF520, which struck me as odd, as I remember them to be a bad fit for a microcontroller project.
Here's a datasheet. Is there a way to guess the RDS(on) at VGS = 3.3 V or 4.5 V from it?
  • \$\begingroup\$ (1) You're right when you say that IRF520 doesn't make a great logic level MOSFET. (2) When you say "\$R_{ds(on)}\$ at 4.5 V", do you mean \$V_{DS} = V_{GS} = \$ 4.5V ? \$\endgroup\$ – Nick Alexeev Jun 20 '18 at 7:35
  • \$\begingroup\$ Guessing is not required as the information is in the graphs. It also tells you, you need at least 4V GS so forget about 3V3. \$\endgroup\$ – Oldfart Jun 20 '18 at 7:41
  • \$\begingroup\$ @NickAlexeev Yes, at least \$V_{GS}\$. \$V_{DS}\$ usually doesn't matter that much, does it? \$\endgroup\$ – AndreKR Jun 20 '18 at 7:41
  • \$\begingroup\$ @Oldfart Oh, Fig. 3, I completely missed that. You want to add an answer? \$\endgroup\$ – AndreKR Jun 20 '18 at 7:44
    \$\begingroup\$ I ordered some MOSFET switch modules. Because they were advertised as "for Arduino" - It seems like every other thingy on Ebay/DX is advertised as "for Arduino", even if it's something like a bare LED (no series resistor). The "for Arduino" qualification is bordering on useless on those sites, at least. \$\endgroup\$ – marcelm Jun 20 '18 at 10:35
Figure 3 show that ID starts at 0 at VGS of 4Volts. The specifications lists the threshold VGS(th) as 2.0...4.0V so I assume the graph is for the 4V worst case. No operation at 3V3!
Assuming you want to use it as a switch, figure 1 shows ID is 1 Amp at VGS and VDS around 4.5V so that would mean a RD(on) of about 4.5 Ohms.
If you look at graph 1 you get the drain current per drain-source voltage for each gate-source voltage.
IRF520 outout graph
The fact that Vgs 4.5V already limits the Id to 1A, means the Rdson is high.
You will need a gate driver.
