I have a simple logic circuit requirement, but can't seem to match any standard flip-flop or latch to my needs (SR, JK, D, MS, level-sensitive or clocked, etc).
The circuit is to disable a H-bridge driver IC if an over-current situation is detected (via a Allegro ACS770 analog-output hall-effect current sensor input to a window comparator, creating the OverCurrent logic-level).
The DISable signal must stay active even if OverCurrent falls back to inactive, until the BridgeEnable is at least deactivated, or optionally deactivated and then reactivated.
Inputs:
BE (BridgeEnable), active-high.
OC (OverCurrent), active-high or active-low, I can flip the comparators either way.
Output:
DIS (Disable), ideally active-low.
This timing-diagram shows the functionality I'm looking for: Timing-Diagram needed
Suggestions?
You can use a standard SR latch. When you make them out of 2 NOR gates, the 1,1 input state, often thought of as pathological to people just wanting a latch, actually performs the logic operation you are looking for.
I'll let you draw out the truth table properly and confirm that it does what you want.
Note that NOR1 always outputs 0 if overcurrent is true, regardless of what BE is doing. And DIS is active low!
  • \$\begingroup\$ duh! thanks for that, can't believe I didn't invert the BE and see the truth-table resemblance to what I needed. and yeah, the 'pathological' avoidance of two 1s (or 2 0s in a NAND S-R) isn't necessarily a deal-breaker, thank for clearing that up for me! \$\endgroup\$ – Techydude Jun 21 '18 at 19:24
You can use a D-register with an active low reset. (Or active high reset and add an inverter).
- Connect the data input high (1)
- Connect the BE to the (active low) reset.
- Connect the OC to the clock.
