I am new in this community. So excuse me if it seems easy.
I want to calculate the amplitude of a specific frequency in a signal. The frequency precision is (relevant question) $$ df = \frac{fs}{NP} $$ $$ fs=1/dt$$ NP is the number of points in the signal time seri. The index of the frequency in the signal is $$ ind = \frac{f}{df} $$ the length of power spectrum array of signal is length(pxx) = NP/2-1
Example 1: for small frequencies
frequency = 1.0/128.0
dt=0.4
df = 0.001
NP = fs/df=2500
index of the signal = 8
lenght of pxx is 1249 so no problem.
Example 2: for large frequencies
freq = 2.0
dt=0.4
NP = fs/df=2500
index of the signal = 2000
The index of the frequency is larger than the number of points in pxx. If I double the number of points in the signal, the frequency precision halves and the index of frequency also doubles. Is there a frequency limit or I am doing something wrong?
Thanks for any guide.
Any Discrete-Time Fourier Transform (with constant sampling frequency) will only give information about the signal up to a frequency of
$$f = \frac{f_s}{2} = f_N$$
\$f_N\$ is called the Nyquist frequency. Frequencies in the signal higher than \$f_N\$ are subject to aliasing (related to the Nyquist-Shannon sampling theorem).
So if you want to find information about a certain frequency \$f_x\$, you will need at least a sampling frequency of \$f_s > 2\cdot f_x\$ and extra to accommodate for an anti-alias filter.
Increasing the number of points will only increase the resolution, without changing the Nyquist frequency.
