I've a pretty simple set up which consists of a PIR sensor and ESP8266. This PIR sensor outputs a HIGH value when presence is detected. This HIGH value lasts for 8 seconds.
I want this trigger to wake up a ESP8266 chip from a deep sleep. To do so, I must send a LOW to the RST Pin.
So with a NPN transistor, I switch it LOW once PIR outputs HIGH.
This works. However, as the HIGH lasts for 8 seconds, the RST remains in LOW and the ESP does not boot until it's back to HIGH.
So question is: Is there any way to convert this long output to become a fast "trigger"?
I attach an screenshot of the schematics in case it helps. enter image description here (credit of the picture: https://github.com/rgrokett/ESP8266_PIRv2/blob/master/ESP8266_PIRv2.pdf)
  • \$\begingroup\$ you might consider using ESPNOW so that you can fire off a message 200ms from power-on, instead of seconds with wifi, which is likely why you want to sleep in the first place. \$\endgroup\$
    – dandavis
    Jun 21, 2018 at 5:37
I think will create enough of a blip to reset the ESP:
  • \$\begingroup\$ This also makes use of a capacitor to do so, as Turbo J suggested in an other answer. How does it differ with his? What is R2 resistance used for? \$\endgroup\$
    – Reinherd
    Jun 20, 2018 at 20:48
  • \$\begingroup\$ It acts as a pulldown and adjustment option together with C1. Turbos version is connected to the collector of a transistor switch. As he said, slight risk of burning the clamping diode with that setup... \$\endgroup\$
    – Dejvid_no1
    Jun 20, 2018 at 20:58
Kind of a hack: Use a capacitor between transistor collector and RST pin. Try using 100nF as a starting value - might need to go higher.
Note that this assumes there is a clamping diode between RST and VCC on the ESP8266, as the capacitor would raise RST above VCC when the transistor turns off. Better don't use a large capacity value here - these diodes don't like too much current.
Mainly you will find a rotary potentiometer in the side of your PIR Sensor PCB. Try decreasing its value and you will find the time has been decreased.
Also refer to This Video, I think it will help
  • \$\begingroup\$ I'm using one without rotary potentiometer. MH SR505 \$\endgroup\$
    – Reinherd
    Jun 20, 2018 at 20:13
    \$\begingroup\$ MH SR505 does have a built in delay of 8 Seconds, this means that once the output signal is high it takes 8 seconds to go back low again so you have to try another solution or a different PIR Sensor. \$\endgroup\$
    – ahm_zahran
    Jun 20, 2018 at 20:30
