28
I am curious about microphones and have a few questions.
  1. What is the key component in them which makes one better than another?
  2. What does it take to build a high quality microphone on my own? I'm looking to purchase a good microphone, and was looking at the Blue Yeti as an example, so that just got me wondering. I know it is better than my dollar store microphone, but want to know why.
  3. Just for kicks, I purchased an el-cheapo Condensor Microphone (2.2K Ohm, 1.5V) to toy around with, but I have little idea regarding its limits. What would a microphone like this one be useful for?
  • \$\begingroup\$ i highly recommend joining the Audio Engineering Society and getting to know some of the manufacturers of transducers there. \$\endgroup\$ Dec 29, 2015 at 19:19
38
Asking what makes one microphone better than another is like asking what makes one car better than another. This is a HUGE subject that I can only give an overview for. But here goes:
Diaphragm
Of course the diaphragm is the most important (but just barely). This is the part that moves in response to the sound and somehow converts the sound to electrical signals. This is the part that determines if your mic is a dynamic, condenser, ribbon, or other type of mic.
To get good frequency response the diaphragm must be very light. The lighter the better. But the lighter something is, the more fragile it is. So steps have to be taken to make it more robust and/or to protect it from damage.
A good diaphragm will also resist environmental damage. Mostly humidity, but also smoke, temperature extremes, shock, etc.
Building a diaphragm is super difficult and requires specialized materials and machinery. This is beyond almost every hobbyist, and even most companies. Odds are that more than 75% of the mic brands sold in places like Guitar Center do not make their own diaphragms-- and it could be as high as 90%.
It is possible to make a diaphragm in your home, but it won't sound good at all. You would be lucky to make one that has "telephone quality".
Sometimes the diaphragm is called the "mic capsule", but that can sometimes be misleading.
Mechanical
The mechanical properties of the mic should not be underestimated. By mechanical stuff, I mean everything that is not the diaphragm or electrical. The body of the mic, the grill, the positioning of the diaphragm inside of the mic and even the mic clip.
It is primarily the mechanical design that determines if the mic is a cardioid, omnidirectional, or hyper-cardioid. Probably more to the point, it is the mechanical design that determines how much unintended noise is rejected. This is done through the placement of the diaphragm and the design of the grill.
Another important task of the mechanical design is to reduce handling noise-- noise caused by someone holding, moving, or adjusting the microphone. In really bad mics, just flexing your hand while holding the mic will be clearly heard.
The mechanical design also helps protect the mic from wind, breath, spit, smoke, beer, etc.
Electrical
Most mics, particularly condenser mics, have electronics in them to boost the signal from the diaphragm before outputting it. Some mics also have simple switchable high-pass filters that further reduce handling and wind related noise.
Of course the electronics have to be low-noise while being able to handle a huge dynamic range without distortion. Even though these circuits are usually very simple, making them high quality is easier said than done.
This gets even harder for the USB-Mics that are coming out. Making a consumer grade USB mic isn't too hard, but a studio grade USB mic is difficult due to the extra electronics.
Consistency
Doing the above things consistently is super important for a microphone manufacturer. Once you have the expensive manufacturing equipment it is relatively easy to make a quality mic. But making two quality mics that match each other in output level, frequency response, transient response, etc. is difficult.
This is super important if you need a pair of mics for stereo recordings. If the left mic has a slightly different frequency response than the right mic then the recording will sound weird. Almost every mic company will sell "matched pairs" of mics, where they go through a batch of mics and find two that are very closely matched. Other companies won't even bother since they have a hard time making 2 that are the same.
Building a high quality mic at home
This is super difficult, but depends on how much you want to do yourself. Making one from scratch is almost impossible because it requires skills and equipment that is rarely found in one person (vapor deposition, electronics, metal fabrication, plastic and/or rubber injection molding, etc.).
You could take one one of those tasks and rebuild an existing mic with that task. For example, you could take a cheap Chinese mic and rebuild or redesign the electronics in it. Or get a metal lathe and milling machine and redesign the body of an existing mic.
It is certainly possible, with some careful research and planning, to take a US$75 mic and make it perform like a US$500 mic.
But don't bother trying to make your own diaphragms if audio quality is your goal. By all means make one just to learn stuff, but don't expect it to sound good.
El-Cheapo Condenser Mic Capsules
These are not useful for much when it comes to professional audio. The quality just isn't there, in noise, frequency response, dynamic range, etc. Professional condensers have a 0.5 to 1.0 inch diameter diaphragm in order to be sensitive and have a better frequency response. The cheap ones are usually less than 0.25 inches, and possibly 0.10 inches.
Mic Arrays
One emerging area of mic research today is the use of microphone arrays. This is where many el-cheapo mics are used and combined in ways that are useful. Normally the mic arrays are used to make a super-directional microphone for teleconferencing and similar applications. This is an area that someone at home can more easily play in and possibly come up with something that works better than what is available commercially.
  • \$\begingroup\$ One thing I've wondered about with microphones, btw, is whether one might improve the performance of a cheap diaphragm by adding a high-frequency (e.g. 100+Khz) transducer near it to bias it, in a fashion somewhat conceptually similar to the use of bias on audio cassettes. From what I understand, a common problem with cheap mics is mechanical friction; if a mic is receiving a 1Khz audio signal, the mechanical friction would superimpose a 1Khz square wave which was anti-phase of the original signal. Adding a 100Khz bias would turn that into a 100Khz square wave, which could then be filtered. \$\endgroup\$
    – supercat
    Aug 16, 2012 at 17:24
    \$\begingroup\$ One would have to ensure that the bias level was low enough not to induce distortions of its own, but I would expect primary limitation on signal level would be diaphragm displacement; since displacement at a given sound pressure level is inversely proportional to frequency, a 100Khz bias shouldn't require much displacement. Any thoughts? \$\endgroup\$
    – supercat
    Aug 16, 2012 at 17:28
    \$\begingroup\$ Some professional mikes have very small diaphragms. These are not usually designed for vocals/instruments, but for drum overheads, stereo-miking and so on. Such mikes are usually known for better frequency response (on or off axis) but not for sensitivity. Large diaphragms have lots of off-axis coloration by nature. \$\endgroup\$ Aug 16, 2012 at 19:38
    \$\begingroup\$ Pro audio folks used to take one of the cheap radio-shack PZM mikes and rebuild the electronics to end up with a great mike for very little money. Last time I checked I couldn't find the same mike anymore. but maybe if you google you'll have better luck. \$\endgroup\$ Aug 16, 2012 at 19:41
    \$\begingroup\$ @rdtsc: Correction: not a fixed-frequency sine wave, but rather filtered noise, so as to avoid aliasing at submultiples of the frequency. The basic idea would be that if a periodic waveform is fed into a microphone, static friction would affect the same part of the wave the same way every cycle; adding noise would cause what would have been periodic distortion to be converted into aperiodic noise. \$\endgroup\$
    – supercat
    Aug 15, 2016 at 14:53
10
Q1
A few things that come to mind are:
  • Dynamic Range - the range between lowest and highest SPL levels the microphone can deal with. For example miking leaves rustling will require a good low level performance, and miking a bass drum will require a good high level performance (i.e. no distortion).
  • Frequency response - flatness across the bandwidth (e.g. 20Hz - 20kHz) is usually desirable, but can be designed for e.g. better bass response.
  • Signal to noise ratio (SNR) and self noise - Signal to noise ratio is the ratio of a reference signal to the noise that the microphone makes with no sound present (self noise). So a high SNR is good, and a low self noise is good. Condenser mics are generally very sensitive, easier to get a good SNR performance from, and therefore good for low level audio.
  • Directivity - how the angle of sound affects the response. Different types of microphone have different patterns. This is affected by both type of element (dynamic, condenser, ribbon, etc) and case design:
Here the direction response patterns (known as polar patterns) for a typical cardioid (left) and shotgun mic (right)
cardioid polar shotgun polar
Usually they are given in 2D, but for those new to them it may be easier to understand if we can see a 3D representation - here is the same cardioid pattern in 3D:
3D cardioid
From these we can see that e.g. if you need to only pick up sound from a specific direction then the shotgun is a good microphone to use.
  • Impedance - how easy it is to match the microphone to various types of equipment, and also how sensitive it might be to noise (e.g. piezo mics, often used on acoustic instruments are very sensitive to vibrations) For example a low impedance mic will be better for use with long cables (avoid picking up hum)
  • Durability - how easily the microphone can be damaged. IIRC ribbon mics are pretty fragile and must be handled with care. Professional condenser elements are pretty easy to damage too. Less fragile types include dynamic (moving coil) and carbon.
  • Price - as with many other things in audio, this is not always dictated by performance. A cheap electret capsule (~£1) when biased properly can have much better frequency response than e.g. an old valve condenser mic that could be hundreds. Here (from Elliott Sound Products) is a discussion and example of using a cheap electret capsule (often maligned, but this is usually due to poor design rather than the capsule itself) to make a test microphone with performance comparable to professional models.
    For an even more detailed and excellent discussion, this thesis compares a test mic built with a ~£1 electret capsule (total cost around £15) with a pro mic setup costing ~£500. The cheap mic outperforms or matches the pro mic in most areas. For example, here is the noise floor for both mics:
Noise floor comparison
Q2
If you want to design the capsule itself, then building a quality microphone will be quite difficult given the fragile and fiddly nature of many types. I would probably go for something like a largish condenser or electret mic - you should be able to get hold of the right film material, or you can get some mylar and apply a permanent charge to it using a HV supply (look up electrostatic speakers for ideas)
Then check out some schematics for the preamp circuit which is necessary in condenser mics (due to their high impedance)
Don't expect your results to be great, but if you do enough research and take your time, you never know. It will certainly be a fun learning project.
If you want to take an existing capsule and build a microphone around it, then it would be much easier to achieve good results. It is certainly possible using readily available components and tools. Reading the above thesis carefully would be an excellent place to start.
Q3
For the third question, it's hard to say without seeing the specs/datasheet, but it will probably be useful as a general purpose speech/music microphone (not for very high levels)
The quality should be suitable for any consumer use, but will probably fall short of "pro audio" standards (although see note above on price, nothing is certain)
The Wiki page on microphones is a good one, very good intro to many different types - worth a read.
  • \$\begingroup\$ I miss S/N ratio and dynamic range! \$\endgroup\$
    – stevenvh
    Aug 16, 2012 at 14:12
  • \$\begingroup\$ @Steven - the dynamic range is alluded to with the sensitivity point and the leaves/bass drum. I will have a think about how to fit S/N in there though (feel free to edit if you want too) \$\endgroup\$
    – Oli Glaser
    Aug 16, 2012 at 14:28
  • \$\begingroup\$ Sorry, Oli, I just scanned the bullets, hadn't seen that you included dynamic range under sensitivity. \$\endgroup\$
    – stevenvh
    Aug 16, 2012 at 14:30
  • \$\begingroup\$ @Steven - no problem, I added a bit on SNR. \$\endgroup\$
    – Oli Glaser
    Aug 16, 2012 at 15:06
  • \$\begingroup\$ I would actually use the mics mentioned in Q3 as measurement mics, particularly in an array for sound direction determination. I highly suspect that they have sub-par performance as vocal microphones at nearly any level. However, when used in an array as @David-Kessner mentions, they could make for a decent synthetic shotgun mic (assuming you have the electronics to back it up). \$\endgroup\$
    – MBraedley
    Aug 21, 2012 at 18:45
I can't speak to the electronics side of things especially, but instead give a sense of what we might look for in a microphone in terms of use, performance, satisfaction and competitiveness when recording audio.
Low self noise as mentioned, for sure. Once we begin applying processes that bring up the noise floor through compression and EQ, self noise will become an issue and if its especially obtrusive will muddy the sound and distract from the performance.
We want consistency of quality regardless of the input, i.e whatever we like during softer passages, we want to like equally if there is more energy, either in terms of volume or sudden shifts in dynamics.
A poor quality microphone, might concievably put in a decent performance with simple, non-challenging audio where the dynamics are very stable and a singer for example is very controlled, but it will crap out in all kinds of subtle and less subtle ways if the vocalist suddenly goes up a gear, or belts or uses a different part of their voice.
This is where your money goes. In making components and designing circuits that can deliver a pleasing sound consistently.
Similarly, we need great microphones to cut through a mix - a whole other demanding feature not easily got around simply by adding a peak in the presence range. It is all about making sure that how it cuts through is pleasing, that we do not need to push the vocal up using brute force with lots of gain, rather that the voice of the microphone is such that it can cut, even at lower volumes in a mix.
Mostly, in lesser microphones I notice that the high end is particularly un-musical, in great microphones the high end is a feature, very soothing and compelling. The low end on poor microphones can be both bassy and woolly and yet counter intuitively sound thinner than microphones with definition and seemingly less warmth.
Crucially, the upper mid of successful microphone designs tends to be the finger print that really determines their worth in the market place, there is typically some robustness here that spotlights the characteristic of the audio most likely to be heared by the non-linear quality of human hearing - which is especially sensitive to the 800 - 3K range. If bad, this is painful. If good, this stages the audio in a very compelling manner.
Overall, great microphones are not amazing in some area but not so good in others. There is little point in them being wonderful in the low end but fall to bits in the high end, furthermore, these distinctive areas, must work together - a truly great upper mid, cannot happen if the high end is harsh and vice versa.
Therefore a truly great microphone makes all of this seem effortless, in some ways almost unremarkable. Rather than transforming the audio that goes into it, it delivers the audio seemingly in a very true form. The real magic is when its effect upon the capture is both transparent yet enhances every nuance of it, such that the end result seems very familiar and yet somehow larger than life.
