Need help identify this varistor. Been trying to figure it out since 5 pm of yesterday. Cannot find anything on it. Any help is greatly appreciated.
\$\begingroup\$ Bump. I could really use the help, guys. \$\endgroup\$ – KoltenS Jun 21 '18 at 6:04
\$\begingroup\$ I'm merely a hobbyist and no professional. But I would have guessed that the "103" would mean 10nF (which can apply to varistors); that although the 560-2 VDE spec can apply either to caps or to varistors, the 5U suggests Y5U (may be consistent with 10nF); and so I'm leaning towards "capacitor." Are you sure it's a varistor? For example, see this from Panasonic ceramic disc caps. \$\endgroup\$ – jonk Jun 21 '18 at 6:14
\$\begingroup\$ I have no idea between the two. But either way, I need to find what company it is from. Not so worried about replacing at the moment or specs. Just need to know who manufactures them. \$\endgroup\$ – KoltenS Jun 21 '18 at 6:18
\$\begingroup\$ Does it still work? Are there any current indications on the silkscreen? \$\endgroup\$ – jDAQ Nov 25 '19 at 5:35
\$\begingroup\$ Funny though that all the other Matsushita varistors I find are ZNR line, none of them are from this NS line. \$\endgroup\$ – jDAQ Nov 25 '19 at 5:53
It seems to be a part from Matsushita, which would now be Panasonic.
I found a few parts with that logo and Matsushita mentioned, but can't find a real source for that.
@jonk mentioned that it is likely a capacitor and not a varistor.
There is a NS-A line of capacitors offered by Panasonic, which could be the successor for the NS you have there.
\$\begingroup\$ Anyone know where I can find a possible replacement then? \$\endgroup\$ – KoltenS Jun 21 '18 at 7:20
