Background:
I have built a number of devices based on the W5100 chip, all them were (are) working more or less decently. However last batch currently in testing show faulty behavior - almost all of them. It confused and upset me a lot, as I used the same type of parts are was using before, but the behavior is definitely different from previous batches. The faulty behavior exhibits as broken communication, reset PHY, RX storms when there're actually no packets on the network.
After replacing the chip (suspecting that it is faulty or I fried it somehow) with no result I decided to desolder all other parts one by one and replacing them with 100% tested parts to find out when behavior changes. I used parts bought and tested before, and parts from Intel network card based on 82546. Magjack - no change, 0.1 uF caps - no change, 4 * 49.9 Ohm resistors - no change.
To my great surprise, issue was solved when I replaced 25 MHz crystal from Intel card together with respective caps from that card. Now W5100 works perfectly without issues.
This points to the fact that clock generation system, attached to W5100, was working wrongly. I have scope, and I measured sinusoidal 25 MHz signal, and did not think there should be something else. Now I think that it is not only the shape of the signal which matters, it is also timing of it - if it constantly having 25 MHz without frequency drifting, and the type of circuit connected to the clock generation circuit. W5100 is having *5 PLL inside, and certainly drift in input frequency may confuse PLL - with subsequent confusion of attached logic.
Question background:
So I started to dig into the clock generation circuit and its operation basics. I never dug into it before, so it was new to me. I found out useful information here on page 16 and here in the answer.
Crystal I used to procure is 25 MHz, 3-pin (3rd pin is crystal's body), 30 pF load capacitance, 27 ppm frequency tolerance. Looking to W5100's datasheet I see the following requirements -
  • Frequency: 25 MHz
  • Frequency tolerance: 30 ppm
  • Shunt capacitance: 7 pF
  • Drive level: 100 uW
  • Load capacitance: 27 pF
  • Aging: 3 ppm p.a.
So my crystal a kind of a little out of requirement for load capacitance, but it is just a little. Could it be the cause I asked myself and if I can make this crystal working anyway? It appeared that I can!
So according to that clever formulas, using this crystal and taking maximal suggested stray capacitance, I should use caps of 46 pF at each side of my crystal:
30 = (x^2 / (2x)) + 7
23 = x/2
x = 46
The closest real life value is 47 pF.
That was huge surprise to me that soldering 47 pF caps I had on hand caused W5100 working properly! WTF I thought?
I decided to look into W5100 datasheet closer.
  1. Datasheet and reference circuits do not have recommended part list, just values with their characteristics. I would love it to have part numbers so that I do not scratch my head over part selection and just ordered the tested parts;
  2. It says crystal load capacitance is 27 pF, and that attached caps are 18 pF each. However using the formula I get:
Cl = 18^2 / (18*2) + Cs
Taking Cs ~ 7
Cl = 9 + 7 = 16
So what the heck datasheet says I need crystal of load capacitance of 27 pF when circuitry assumes 16 pF? Do internals of tiny W5100 chip adds another 11 pF - and I doubt so for simple reason - chip heats a lot while operating, and putting capacitance into the chip will make it drift with temp (even if it is NP0-kind).
Question itself:
  1. I do not recall I saw clock generation circuit before with caps' capacitance of as high as 47 pF. Are these caps values too high, up to circuit being bad in some respect?
  2. Do you think I can keep this circuit with my current crystal (load cap of 30 pF) and current caps (47 pF - CC0805JRNP09BN470), or must change parts completely?
  3. Do I miss anything regarding W5100 datasheet and its explanation of the typical crystal on page 68? Reference circuit with caps can be found here in zip archive. Looking at it now I see even 13 pF caps (I am sure previous version was having 18 pF).
  4. W5100's clock generation circuit features 1 MOhm resistor in parallel to the crystal. Does it change formula, and how?
Update:
Did you specify and measure the PCB layer stackup?
No, I have no equipment for it. Did not think it should be so important if I follow manufacturer's guidelines, and have design reviewed by the WIZnet (wanted to say "approved", but it is not the case :)
Is it the same as in other batches?
All boards are manufactured by the same manufacturer in China, and layout is (was) the same.
A bias resistor gives the internal unbuffered inverter negative feedback to ensure that it is biased correctly. I'm unsure after reading your question whether you used one or one was internal to your chip.
It is there, and always was there, soldered into the board. Caps were the same as in the previous batch; 1 MOhm resistors are the same for all batches. Crystal oscillator was always procured from the same store. I had 2 boards defected in previous batch out of several dozens - for the same reason I defect almost all in this batch, but I did NOT investigate further that time, thinking that it is an issue with soldering or something else.
"After replacing the chip" was that from the same batch?
Bought new in another store, datecode was different.
I also suggest you show the PCB lay-out.
You should locate crystal easily, with caps and resistor in the circuit. Short tracks, close to chip, no tracks on top or bottom to influence operation, empty space is filled with GND (not seen on this polygon-less picture).
Caps and resistor are on the top, crystal is inserted through-hole from the bottom. Two resistors to the left are for PHY reference voltage, at the top. Crystal is having 3 pins, with center being ground (body of the crystal).
Please note that in my questions I do not only ask to help me resolve my issue and examine if I did things right, I also ask to review WIZnet documentation and what they say in datasheet to see if they are wrong and/or they need to properly update their documentation (datasheets and/or reference schematic) so that other people do right from the start.
  • \$\begingroup\$ Please also take into account the process tolerances and layout of your PCB. This has a huge effect on stray capacitance and thus on the crystal frequency. Especially when the crystal is designed at the edge of properly working, the PCB difference from one batch to another can make the difference. Did you specify and measure the PCB layer stackup? Is it the same as in other batches? \$\endgroup\$ Jun 23, 2018 at 8:50
  • \$\begingroup\$ Q4 - A bias resistor gives the internal unbuffered inverter negative feedback to ensure that it is biased correctly. I'm unsure after reading your question whether you used one or one was internal to your chip. \$\endgroup\$
    Jun 23, 2018 at 9:55
  • \$\begingroup\$ "After replacing the chip" was that from the same batch? Process variations can be huge between batches. So you can have a few thousand all with a lower amplification of your crystal oscillator. But again: it looks like a marginal design. I also suggest you show the PCB lay-out. (Not to me, I am not an expert on this) \$\endgroup\$
    – Oldfart
    Jun 23, 2018 at 9:57
  • \$\begingroup\$ updated question \$\endgroup\$
    – Anonymous
    Jun 23, 2018 at 12:31
Question 4 - W5100's clock generation circuit features 1 MOhm resistor in parallel to the crystal. Does it change formula, and how?
You must have the 1 Mohm resistor in place as per the schematic for the clock circuit to work correctly and reliably: -
If the resistor is not internal to the chip then it has to be applied externally. It gives negative feedback to the internal buffer and biases its input at precisely the right point for optimum oscillation.
  • \$\begingroup\$ Yes, I was also wondering if they left it out, that is why I asked for the PCB lay-out. \$\endgroup\$
    – Oldfart
    Jun 23, 2018 at 10:18
  • \$\begingroup\$ updated the original question with required info \$\endgroup\$
    – Anonymous
    Jun 23, 2018 at 12:28
  • \$\begingroup\$ hopefully you can solder one on top of the existing caps to be sure if this is the issue. Good question, this is the kind of issue that keeps guys like us awake at night. \$\endgroup\$
    – danmcb
    Jun 24, 2018 at 10:16
A required frequency tolerance of 30ppm is a rather tight requirement for your circuit, especially over some temperature range.
Obviously, you are trying to calculate the necessary caps, but as you dont know the stray and input capacitance of your circuit, your calculations are (almost) useless.
What you need to do is to actually measure the clock with a <1pF probe and a >9 digit precision counter. Then you can fine-tune the caps until you get something below 5ppm deviation at room temperature.
In the end, you must define and supervise your PCB in production, because if you have a difference in layer stackup in one batch, it will violate the 30ppm easily.
  • \$\begingroup\$ Let's not be endlessly perfect: I do not need mathematically precise values, I need circuit to work. Calculations may be useless, but for some reason calculated values worked well. Can you please give more practical advice than taking expensive device (not every lab is having), and then making super precise measurements up to 1^(-12)? And how you see me supervise PCB production in China if I am not located there? You advice sounds for company like Flextronics, Apple or Intel. \$\endgroup\$
    – Anonymous
    Jun 23, 2018 at 16:44
  • \$\begingroup\$ I see several sources saying that "the sum of parasitic capacitance in the PCB trace and the capacitance in the terminal of the crystal ... will typically be in the range of 2 – 8 pF", thus me taking 7 pF seems to be reasonable ti.com/lit/an/swra372c/swra372c.pdf \$\endgroup\$
    – Anonymous
    Jun 23, 2018 at 16:55
  • \$\begingroup\$ Ok, maybe 12 digits is a bit too much, but I recently bought a timer that has sub ppm resolution for about 200 dollars which serves me perfectly for this kind of measurement. But maybe even your scope has sufficient timing resolution for this measurement. Also the <1pF probe is not needed, if you get some clock out of your W5100. I keep sticking to it: If you want to do it right, you need to measure and tune it. \$\endgroup\$ Jun 24, 2018 at 13:08
  • \$\begingroup\$ Stefan, thank you. Apart from the making measurements of the crystal waveform with the scope, can you look into the list of questions in the post and share your views on them? \$\endgroup\$
    – Anonymous
    Jun 24, 2018 at 19:49
  • \$\begingroup\$ A ground plane adds alot of capacitance to both terminals. so without is better then Cs is minimal due to Ciss of inverter 2pF which is not added to Cload/2 but in parallel with only CL1 of 2, so I have always chosen OSCI cap to be 2 pF lower than OSCO side. with Rs \$\endgroup\$ Aug 11, 2020 at 20:05
