I want to shorten the width of a single pulse to 50ms or 100ms width. For example, a circuit generates a positive pulse of duration 1 sec and I need to reduce its width to 50ms, synchronized to the rising edge of the input pulse. How can I do this? Thanks
  • \$\begingroup\$ Is this for 5V logic? \$\endgroup\$ Jun 24, 2018 at 15:08
What you want is called a monostable multivibrator, or one-shot for short. You set it up to trigger on the leading edge of your signal. It will the produce a pulse of fixed duration.
You set the duration with timing components, like a resistor and capacitor. There are 74xxx series chips that are intended for exactly this purpose. Look thru a selector guide.
  • \$\begingroup\$ I would recommend to use a non retriggerable monoflop for this task. \$\endgroup\$
    – Uwe
    Jun 24, 2018 at 15:19
  • \$\begingroup\$ Thank you, can you suggest a schematic. I can calculate the rc timing. All I want is the the circuit to work when the output pulse width be shorter than the input. \$\endgroup\$
    – JTrah
    Jun 25, 2018 at 9:06
  • \$\begingroup\$ I 've managed to work with 74ls122. thanks \$\endgroup\$
    – JTrah
    Jun 26, 2018 at 11:44
