Based on a question I asked earlier today, I am trying to verify that there's not short caused by my bad soldering.
Luckily I had bought two of these modules. To make a baseline, I started looking at the module that I had not done anything to.
Using this Multimeter (on a disconnected module -- it has no solder and no wires in/out), I am pressing the black lead again the MOSI pin (see diagram below) and moving the red lead one pin down, one pin at a time.
However, I am not entirely sure what I am looking at, for example:
With black on MISO and red on MOSI, or SCK, the reading is 350+K Ohms.
With the black on MISO and read on RESET, the reading is 150+K Ohms.
With black on MISO and red on DIO5, the reading is 1.05K Ohms and red on GND shows 0.5K Ohms.
When I compare that with this video for example, his reading stays at 1 across pin changes.
Again, this is an untouched board, direct from the seller. So is my understanding not correct (i.e. the readings are fine and I don't know what they mean)? Or is it a bad module?
