I have to design 3-bit up synchronous counter using JK flip-flops.
The first one should count even numbers: 0-2-4-6-0
The second one should count odd numbers: 1-3-5-7-1
Execution Table For JK Flip Flop:
Q(n) Q(n+1) J K
0 0 0 X
0 1 1 X
1 0 X 1
1 1 X 0
First question: design a negative-edge-triggered synchronous counter with the form of operation: 0-2-4-6-0
Second question: Design a negative-edge-triggered synchronous counter with the form of operation: 1-3-5-7-1
Main question: I made two designs like the pictures above. But as you can see, the JK output is the same. That's weird! In both designs (even and odd) the J(C) output = Q(B) and K(C) output = Q(B). And in this case, will this odd-number circuit count by two-by-two?
Why are the results the same? Where exactly am I making a mistake?
Hint:
In the first even-counter circuit, the value of the K(A)
can take 1 or 0.
In the second odd-counter circuit, the value of the J(A)
can take 1 or 0.
