I'm using stm32l100C6-A to communicate with gas gauge via I2C. My code tries to start I2C transfer, like this:
I2C1->CR1 |= I2C_CR1_START;
// waiting for EV5 - Master Mode Select
while( ! (I2C1->SR1 & I2C_FLAG_SB) );
<yadda..yadda..>
and sometimes it works, transfer is completed, all is well. But some other times instead of full transfer on I2C lines I see this (SCL and SDA are in different scale): enter image description here
As far as I can see - that's just a normal start condition. But I2C1->SR1 is zero, no bits are set, no matter how long I wait.
After that - making I2C reset via I2C1->CR1 |= I2C_CR1_SWRST; doesn't help, making full reinitialization of I2C doesn't help, resetting RCC for I2C doesn't help. Only full MCU reset helps.
Since full reset helps, the problem must be in the MCU but I couldn't find anything similar in the errata or internet.
I'm using I2C on 85kHz.
I have no idea what's going on and I don't like resetting MCU as a workaround. Any ideas?
  • \$\begingroup\$ Is your peripheral clock at least 2MHz? \$\endgroup\$
    – Annie
    Jul 12, 2018 at 20:45
  • \$\begingroup\$ Yes, it's 32 MHz, straight from PLL. \$\endgroup\$
    – Amomum
    Jul 12, 2018 at 21:47
