I have a circuit that has a 24V power rail and I put an LED and series resistor on it for power indication. Even at 10mA forward current, over 200mW of power is dissipated, over 90% of it in the series resistor. This is more than many (but not all) SMD resistors can even provide. This seems like a lot of power for a simple LED.
Neon indicators might work at the higher voltage end, but they aren't commonly available in SMD packages and they're bulky, expensive and can have limited life.
I also considered an astable multivibrator to do a low-duty cycle flash to keep average power down, but that needs 4 resistors, 2 capacitors and 2 transistors, or an IC (which would be unlikely to work at 24V) and some passives.
Is there a very simple (low component count, cheap, low-power and low-board-area) way to show power indication in circuits with a rail voltage more than about 10 times the LED \$V_f\$ (say around 15V up to 48V).
