I have problem with reading data from MPU6050 to STM32F4 nucleo board. The connection is with I2C. The problem is that in the first function IsDeviceReady the device is recognised and the LED does turn on but when I set the data in i2cBuf[1] = 0x08 and send it, after receieving that data, i2cBuf[1] is set to 0x00 - so as it is set before receiving data. Do you maybe know what could be the problem? Thank you.
Code:
#include "stm32f4xx_hal.h"
#include <string.h>
void GPIO_Config(void);
void I2C_Config(void);
void UART_Config(void);
void DMA_Config(void);
#define mpu6050Address 0xD0
I2C_HandleTypeDef MBI2Chandle;
UART_HandleTypeDef MBUARThandle;
DMA_HandleTypeDef MBDMA_Uart2Handle;
//UART Test
char txData[40] = "Hello from STM\r\n";
char rxData[40];
//I2C variables
uint8_t i2cBuf[8];
int16_t ax,ay,az;
float Xaccel, Yaccel, Zaccel;
int main(void)
//HAL Initialise
HAL_Init();
//Config functions
GPIO_Config();
I2C_Config();
UART_Config();
DMA_Config();
//1. Scan the I2C adresses
for(uint8_t i=0; i<255; i++)
    if(HAL_I2C_IsDeviceReady(&MBI2Chandle, i, 1, 10) == HAL_OK)          //test for the slave address
        HAL_GPIO_TogglePin(GPIOB, GPIO_PIN_7);
        break;
//2. I2C Write example
//a) Set accelerometer range (reg28)
i2cBuf[0] = 28;         //Register address: Accelerometer config 1
i2cBuf[1] = 0x08;       //Data to write, +-4g range
HAL_I2C_Master_Transmit(&MBI2Chandle, mpu6050Address, i2cBuf, 2, 10);
//3. I2C Read example
//Request to read from a register (reg 28)
HAL_I2C_Master_Transmit(&MBI2Chandle, mpu6050Address, i2cBuf, 1, 10);
//Read data
i2cBuf[1] = 0x00;
HAL_I2C_Master_Receive(&MBI2Chandle, mpu6050Address|0x01, &i2cBuf[1], 1, 10);
while(1)
    //4.Read accelerometer data
    i2cBuf[0] = 0x3B;       //Register address: X_axis H
    //Read data
    i2cBuf[1] = 0x00;
    HAL_I2C_Master_Receive(&MBI2Chandle, mpu6050Address|0x01, &i2cBuf[1], 6, 10);
    ax= -(i2cBuf[1]<<8 | i2cBuf[2]);
    ay= -(i2cBuf[3]<<8 | i2cBuf[4]);
    az= -(i2cBuf[5]<<8 | i2cBuf[6]);
    Xaccel = ax/8192.0;
    Yaccel = ay/8192.0;
    Zaccel = az/8192.0;
    HAL_Delay(50);
    //UART Test
    HAL_UART_Transmit(&MBUARThandle, (uint8_t *)txData, strlen(txData), 10);
    HAL_Delay(500);
   //Enable Ports clocks
__HAL_RCC_GPIOD_CLK_ENABLE();
__HAL_RCC_GPIOB_CLK_ENABLE();
//Init typeDef
GPIO_InitTypeDef MBPinInit;
//LED pins config
    //PB7 BLUE LED
MBPinInit.Pin = GPIO_PIN_7;
MBPinInit.Mode = GPIO_MODE_OUTPUT_PP;
MBPinInit.Pull = GPIO_NOPULL;
MBPinInit.Speed = GPIO_SPEED_FREQ_LOW;
HAL_GPIO_Init(GPIOB, &MBPinInit);
//I2C pins config
    //I2C1_SCL PB8, I2C1_SDA PB9
MBPinInit.Pin = GPIO_PIN_8 | GPIO_PIN_9;
MBPinInit.Mode = GPIO_MODE_AF_OD;
MBPinInit.Pull = GPIO_PULLUP;
MBPinInit.Speed = GPIO_SPEED_FREQ_VERY_HIGH;
MBPinInit.Alternate = GPIO_AF4_I2C1;
//Systick interrupt enable for HAL_Delay function
HAL_SYSTICK_Config(HAL_RCC_GetHCLKFreq()/1000);
HAL_SYSTICK_CLKSourceConfig(SYSTICK_CLKSOURCE_HCLK);
HAL_NVIC_SetPriority(SysTick_IRQn, 0, 0);
__HAL_RCC_USART2_CLK_ENABLE();
GPIO_InitTypeDef MBUartDef;
MBUartDef.Pin = GPIO_PIN_5 | GPIO_PIN_6;
MBUartDef.Mode = GPIO_MODE_AF_PP;
MBUartDef.Pull = GPIO_PULLUP;
MBUartDef.Speed = GPIO_SPEED_FREQ_VERY_HIGH;
MBUartDef.Alternate = GPIO_AF7_USART2;
HAL_GPIO_Init(GPIOD, &MBUartDef);
//UART Configuration
MBUARThandle.Instance = USART2;
MBUARThandle.Init.BaudRate = 115200;
MBUARThandle.Init.Mode = UART_MODE_TX_RX;
MBUARThandle.Init.WordLength = UART_WORDLENGTH_8B;
MBUARThandle.Init.StopBits = UART_STOPBITS_1;
MBUARThandle.Init.OverSampling = UART_OVERSAMPLING_16;
HAL_UART_Init(&MBUARThandle);
//System interrupt enable
//Enable I2C peripheral clock
__HAL_RCC_I2C1_CLK_ENABLE();
MBI2Chandle.Instance = I2C1;
MBI2Chandle.Init.AddressingMode = I2C_ADDRESSINGMODE_7BIT;
MBI2Chandle.Init.ClockSpeed = 100000;
MBI2Chandle.Init.DualAddressMode = I2C_DUALADDRESS_DISABLED;
MBI2Chandle.Init.DutyCycle = I2C_DUTYCYCLE_2;
MBI2Chandle.Init.GeneralCallMode = I2C_GENERALCALL_DISABLED;
MBI2Chandle.Init.GeneralCallMode = I2C_NOSTRETCH_DISABLED;
MBI2Chandle.Init.OwnAddress1 = 0;
MBI2Chandle.Init.OwnAddress2 = 0;
HAL_I2C_Init(&MBI2Chandle);
void SysTick_Handler(void)
HAL_IncTick();
HAL_SYSTICK_IRQHandler();
__HAL_RCC_DMA1_CLK_ENABLE();
MBDMA_Uart2Handle.Instance = DMA1_Stream5;      //pdf str 196
MBDMA_Uart2Handle.Init.Channel = DMA_CHANNEL_4;
MBDMA_Uart2Handle.Init.Direction = DMA_PERIPH_TO_MEMORY;
MBDMA_Uart2Handle.Init.PeriphInc = DMA_PINC_DISABLE;
MBDMA_Uart2Handle.Init.MemInc = DMA_MINC_ENABLE;
MBDMA_Uart2Handle.Init.PeriphDataAlignment = DMA_PDATAALIGN_BYTE;
MBDMA_Uart2Handle.Init.MemDataAlignment = DMA_MDATAALIGN_BYTE;
MBDMA_Uart2Handle.Init.Mode = DMA_CIRCULAR;
MBDMA_Uart2Handle.Init.Priority = DMA_PRIORITY_LOW;
MBDMA_Uart2Handle.Init.FIFOMode = DMA_FIFOMODE_DISABLE;
HAL_DMA_Init(&MBDMA_Uart2Handle);
__HAL_LINKDMA(&MBUARThandle, hdmarx, MBDMA_Uart2Handle);
//Enable DMA1 Stream 5 interrupt
HAL_NVIC_SetPriority(DMA1_Stream5_IRQn, 0, 0);
HAL_NVIC_EnableIRQ(DMA1_Stream5_IRQn);
 void DMA2_Stream5_IRQHandler(void)
HAL_DMA_IRQHandler(&MBDMA_Uart2Handle);
  • \$\begingroup\$ You need to figure out if the I2C bus operation is completing or not. The buffer values only have meaning if the bus operation complete. See the documentation of your I2C driver functions, or examine their code if the documentation is insufficient. You can also monitor the bus, but it should be possible to determine this from software alone. \$\endgroup\$ – Chris Stratton Jun 25 '18 at 14:58
  • \$\begingroup\$ @ChrisStratton can you tell me how exactly can I check if the bus operation is completing or not? Thank you. \$\endgroup\$ – Marko Boršić Jun 25 '18 at 15:17
    \$\begingroup\$ As I already said, you'd need to dig into the documentation or the code of the interface routines, or monitor the bus with test equipment. \$\endgroup\$ – Chris Stratton Jun 25 '18 at 15:20
