So we bought five LM35DZ, in the previous days, when we use the multimeter to measure the voltage between Vout and GND, the results were correct and logic, and when we exposed LM35 to a heat source, the voltage increased, But the problem was with Arduino, the results were unstable and illogical! We checked internet, and we found some possible reasons!
  • Sharing the GND was one of them, but we only use the LM35, so we don't share the GND with any other device
  • Another possible reason is due to the unstable source, because we're feeding the Arduino from the USB and this can lead to wrong results, because of the ADC converter, there are some ways to eliminate such problem, we chose to read the 3.3 V pin of Arduino and use it as a reference
    unsigned int temp = 0;
    unsigned long temptot = 0;
    unsigned int REFtemp = 0;
    unsigned long REFtemptot = 0;
    int x;
    int REFSensor=  A1,
    LMSensor=A0;
    void setup() {
        pinMode(REFSensor,INPUT);
        pinMode(LMSensor,INPUT);
        Serial.begin(9600);
    void loop() {
        temptot = 0;
        REFtemptot = 0;
        for(x = 0; x < 64; x++) { analogRead(REFSensor);}
        for(x = 0; x < 64; x++) {REFtemptot += analogRead(REFSensor);}
        for(x = 0; x < 64; x++) {analogRead(LMSensor);}
        for(x = 0; x < 64; x++) {temptot += analogRead(LMSensor);}
        temp = temptot >> 6;
        REFtemp = REFtemptot >> 6;
        float y= (float(REFtemp)*3.3)/676.;
        Serial.print("Vcc: " ); Serial.print(y*1023./676.); Serial.print("v  ");
        Serial.print("REF: " ); Serial.print(y); Serial.print("v  ");
        float volt= (float(temp)*3.3)/float(REFtemp);
        // Serial.print("V.LM: " ); Serial.print(volt*1000.);  Serial.print("mv   ");
        Serial.print("T.LM: " ); Serial.print(volt*100);   Serial.println("C " );
  • Another problem is the noise and many attempts to add a 100nF capacitor between Vcc and GND, we don't have 100nF so we used 10nF
  • Also to smooth the results we add another capacitor (1pF to 10pF) between Vout and Arduino pin (A0 in our case)
So today and after making all these changes, what happen is that the results were stable but illogical; in room temperature we read 10C to 12C, and when we removed one or both capacitors the results go crazy (between 100C to 10C) and the most strange event is that when we expose the LM35 to heat, the temperature decreases
We checked the LM35 using the multimeter and here the surprise! The voltage between Vout and GND was between 1000 mV to 3000 mV, and when we expose the LM35 to heat it decreases to 200 mV. I'm saying it is a surprise because all the five LM35 start acting in the same way. Is it possible that we burn all of them at once? If this is the case, how and when this happened? I remember we switched between the Vcc and GND of one of the LM35 which can cause damage, but as I said just one. Not all of them.
So anyone can help? We decided to buy another LM35 and check it, who knows!
UPDATE-------------------------------------------------------------------------
The big capacitor is between GND and Vcc it is about 100pF, sometimes we don't use it, in this case the signal become very unstable, the small one is about 1pF, sometimes we put it between Vout and Gnd! I don't know why we used it, but it made the signal more stable!
this is the signal between Vout and GND, we removed all capacitors, it gave 0v, I don't know why! it gave 1v to 3 volt using multimeter
we fed the LM35 with 5 volt
enter image description here The signal here was taken between Vout and Vcc(5volt), it should be 5volt, because it is 0v between Vout and GND!
I don't know why it looks like that! apparently there is no big noise!
The last picture is between Vcc and GND, it gave 5volt as expected!
Now! I'm not sure why we got such illogical results! maybe the LM35 was damaged but even with this possibility, the signal between Vout and GND shouldn't be 0!
The usual problem with LM35 instability is excessive capacitive loading caused by cables, external capacitors or input capacitance. See Page 14 of the TI datasheet.
The 2K series resistor or the RC damper are not optional if the capacitive loading exceeds about 50pF. That's easily exceeded with even a short screened (shielded) cable.
Forget what the Arduino reads for now, leave it connected and debug the sensor using a simple multimeter.
    \$\begingroup\$ Yes this coincidentally duplicates my answer and twisted pair UTP is 50pF/m with twists every 2cm while STP and coax are better but 100pf/m. Series or shunt Dampening is a “ must have” Note to @Samah, the power-on step response with no load is already ringing near 100kHz . That is your clue. \$\endgroup\$ Commented Jun 25, 2018 at 17:50
  • \$\begingroup\$ At least they're oscillating consistently. \$\endgroup\$ Commented Jun 25, 2018 at 18:42
  • \$\begingroup\$ Great waves think alike in frequency, unless it’s a Tsunami \$\endgroup\$ Commented Jun 25, 2018 at 18:57
    \$\begingroup\$ @TonyStewartolderthandirt Great minds think alike; fools seldom differ is another one. \$\endgroup\$ Commented Jun 25, 2018 at 19:03
  • \$\begingroup\$ I avoided that old cliche \$\endgroup\$ Commented Jun 25, 2018 at 19:05
If you want to see why more noise clipping from oscillations causes a lower DC voltage see here.
Datasheet says:
The low-output impedance, linear output, and precise inherent calibration of the LM35 device makes interfacing to readout or control circuitry especially easy.
The more you follow TI’s Fig 12 or 13, the easier it gets.
http://www.ti.com/lit/ds/symlink/lm35.pdf
To maintain low impedance , long loose wires are not allowed due to antenna effects picking up noise.
The signal wires must be coax or STP (shielded twisted pair CAT5,6) or just UTP for short distances. Floating grounds and Common Mode (CM) noisy SMPS can be suppressed further with >1nF from 0V to earth ground but if above is properly routed not essential.
Cable length matters so use STP if in doubt. Then read more about shielding.
Don’t forget to include a small 0.1uF Vcc cap near the sensor. Then add either series R or shunt RC before long cable. 0.01uF is marginal and 10pF does nothing at 100kHz to lower impedance. But it must be done at source.
The reason it fails is because it has a Source Follower like emitter follower that can oscillate near 100kHz (here) with the large cable capacitance load (100pF/m ~) without either raising the series R or drowning high f currents with low R big C in shunt.
  • \$\begingroup\$ THANK YOU TONY, we're using short cable (less than 20cm)! so I'm not sure what kind of components I have to add and where ! can you help? \$\endgroup\$
    – Samah
    Commented Jun 25, 2018 at 20:12
  • \$\begingroup\$ Can you scope it with similar short gnd leads? You may need noise shunt to earth gnd or better PS CM choke to raise inductive impedance. Although if Scope is earth grounded that may also clean up the signal and results. If so then you can earth ground DC at source. (There are other ways if battery operated but we need photos of layout. You are WELCOME Samah. Also scope Vcc etc \$\endgroup\$ Commented Jun 25, 2018 at 20:21
  • \$\begingroup\$ - I tried to read about the" short gnd leads", so it is apparently about removing the standard ground lead of the oscilloscope and using a short one! am I right? - When you talked about the noise shunt, did you mean to use RC circuit? - And how can I earth ground DC at source? I mean what does it mean ? \$\endgroup\$
    – Samah
    Commented Jun 25, 2018 at 21:33
  • \$\begingroup\$ Use scope earth ground at 0Vdc input for this test and reply with changes in results or hardware to earth ground nearby \$\endgroup\$ Commented Jun 25, 2018 at 22:23
  • \$\begingroup\$ Pls post analog waveforms and layout photo \$\endgroup\$ Commented Jun 25, 2018 at 22:59
