This connector is out of a Sega Dreamcast. I need a new wiring harness but can't find out what this plug is.
enter image description here enter image description here enter image description here
The plug is 6.54mm wide, 3.42mm high (excluding the "key" 4.08 with the key), 6.48mm deep.
I can just about make out the letters JST, but very small. I can't get the camera to focus.
    \$\begingroup\$ try to look for it on the Molex website \$\endgroup\$ – Nazar Jun 26 '18 at 12:04
    \$\begingroup\$ @Titchg If you want to increase chances for getting an useful answer add exact dimensions and look out for manufacturer symbols and features like the first pin designation. Post pictures of embossed numbers and symbols. (My bet is J.S.T.) \$\endgroup\$ – Ariser Jun 26 '18 at 12:18
    \$\begingroup\$ And inline your images. Most of us don't have time to follow links just to see what the question is about. You might be limited to two images inline because you are new. Someone will fix up the other one for you. \$\endgroup\$ – Transistor Jun 26 '18 at 12:38
    \$\begingroup\$ @Titchg Try a search for "jst 3 pin connector". \$\endgroup\$ – Andrew Morton Jun 26 '18 at 12:46
    \$\begingroup\$ Possible duplicate of What type of connector is this \$\endgroup\$ – user103380 Jun 26 '18 at 15:13
Incase anyone is looking for a dreamcast fan plug in the future I can confirm it is a JST PH.
Thanks everyone.
