I have a curcuit which outputs two different pulse signals from two different "PWM generator(DC-DC)" block. I will apply these signals to two different mosfets. Thus I need to create a dead time to prevent short circuit.
To achive this, i tried to use "transport delay" and "on/off delay" blocks. The shifting part worked but after applying them to the mosfets the current become weird.
I thought to transfer the signal to the workspace and try shifting there or using "Matlab Function" block but i don't have an idea how to.
I would appreciate any idea and help.
the circuit the current with transport delay
  • \$\begingroup\$ Did you ever hear about the term "dead time" and a corresponding hardware approximation proposed by Padé - consisting of resistors and capacitors only? \$\endgroup\$
    – LvW
    Jun 26, 2018 at 12:41
  • \$\begingroup\$ Perhaps this similar question will help you. \$\endgroup\$ Jun 26, 2018 at 12:42
  • \$\begingroup\$ LvW i know what is "dead time" however not really have idea about Pade approximation. I am sorry. Thanks Harry for helping, i edited my title thanks to you. I forgot to mention that I am working in simulink to model a system(could not have chance to work with Ardunio and "real" stuff). \$\endgroup\$
    – Gökhan
    Jun 26, 2018 at 13:57
    \$\begingroup\$ Could you share the plots illustrating the problem? (that is, "the current become weird") \$\endgroup\$ Jun 26, 2018 at 14:11
  • \$\begingroup\$ I tried to share the plots but i don't know if it worked. I think i have a problem with i.stack.imgur.com. Anyway if you can't see the plot i am trying to explain with words; the current from non-delayed gate signal has a good sine shape with pulses. (pulses are forming a sine shape) However in the plot of the current from delayed gate signal there are two symmetrical region in each cycle which have peaks. \$\endgroup\$
    – Gökhan
    Jun 27, 2018 at 11:24
