I am fairly new in the electronics world, but I would really like to learn it. The problem I'm facing right now, is that I miss the insight to be able to tackle this specific problem.
I have to calculate the input resistance of a system on the basis of a given ADC value. There will be an temperature sensor connected to the input, which will give some resistance, depending on the temperature. What I want to know / calculate, is the given resistance, so that I can calculate the right temperature. I know how to convert the ADC value to the correct voltage, but I do not know what the next steps are.
I calculate the voltage as follows: \$\text{Result}_{\text{mV}} = (\text{Reference}_{\text{mV}} / \text{BitSteps}) \times \text{ADC}\$
That gives the correct voltage at the input of the ADC.
Given the following diagram, which follow up steps should I take to calculate the input resistance?
74HC4052 Dual 4-channel analog multiplexer/demultiplexer data sheet
