I am working on a 3D tracking interface project that I found online here.
However, instead of using my hand to track, I want to track an aluminum ball with a 2 cm radius, which is connected to ground. I am also using thin metal aluminum plates instead of foil.
I can't get the distance I need, which is about 35 cm. How do I increase the measuring distance of the plate to reach at least 35 cm?
This is the circuit:
