I hope you can help me since I believe this is a very specific error and I do not know how to solve.
I want to divide 2 numbers represented like:
  • 4bits : integer part
  • 4bits : fractionary part
So I instance a divisor in the xilinx core generator and this parameters
  • Signed
  • Fractionary Part (instead or remainder)
and with this ports:
component div8_signed
    port(
        clk : in std_logic;
        dividend : in std_logic_vector(7 downto 0);
        divisor : in std_logic_vector(7 downto 0);
        quotient : out std_logic_vector(7 downto 0);
        fractional : out std_logic_vector(7 downto 0)
end component;
Then for testing I try to implement the division between these numbers (for example):
  • Division1: - 2 / 1.5
  • Division2: - 1.5 / 2
So I do fixed point calculations before going to the VHDL and I get these values with this representation:
Division 1:
r = x/y
  Floating P. Fixed point  Hex  Bin
x: -2.000000, X: -2.000000 0xe0 0b11100000
y: 1.500000,  Y: 1.500000  0x18 0b00011000
r: -1.333333, R: -1.312500 0xeb 0b11101011
Division2:
r = x/Y
  Floating P. Fixed Point  Hex  Bin
x: -1.500000, X: -1.500000 0xe8 0b11101000
y: 2.000000,  Y: 2.000000  0x20 0b00100000
r: -0.750000, R: -0.750000 0xf4 0b11110100
So I get it simulated and here are the results: enter image description here
The quotient and the fractionary part are wrong according to my calculations. I know that I would need to take the last 4 bits of the quotient for the integer part of the result and the first 4 bits of the fractionary for the fractionary part. But still the quotient and the fractionary shows numbers that do not match with what I was expecting to see.
Doing some trial and error I found that for divisions of signed numbers in the next combinations work or not:
  • positive / positive : works
  • negative / negative : works
  • positive / negative : do not work
  • negative / positive : do not work
I have already tried everything without success and I do not know how to make this work. Any idea of what can be happening?
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
