I am beyond puzzled with identifying the values of a wire wound, axial, through hole resistor that I'm replacing on a MRC Super Brain 989 relic that I burnt up after 50+ hours of charge/discharge cycles of (20) 6-cell NiMH battery sticks that make up the IMA battery in my Honda Civic Hybrid; in efforts to rebalance the pack.
The failed resistor, or actually a series of (4) identical resistors are responsible for the 10A discharge rate the 989 is capable of. I was pushing the discharge circuit beyond limits with dozens of discharges on these sticks at a 10A discharge rate at a 0.9mV/cell peak cut-off, resulting in a 6180mAh discharge capacity per stick.
The charger pauses the discharge cycle when the internal temp reaches 185ºF and resumes discharge when temp drops to 175ºF. This pause/resume would happen several times during a discharge.
All that being said....The resistors in need of replacing measure 17mm in can length and 6mm in diameter, and all 4 resistors read out on a MM with a resistance value of 0.5-0.7 Ohms.
*****THE 5-BAND COLOR SEQUENCE******
{ |BROWN| |BLACK| |SILVER| |RED| |BLACK| }
The best I can come up with is: (0.1 Ohm with 2% Tolerance) by ignoring the ending black band and treating this as a 4-Band Resistor.
The goal is to replace the resistors with a better grade, add more fans, and extend heat sink to get the charger in a workable condition to finish the project at hand.
Thanks!!
