In circuit diagrams, Josephson Junctions are sometimes given as an X
and sometimes as an X with a box around it ☒
. What is the difference?
1\$\begingroup\$ Personal preference of the creators? JJs are not common enough items to have their own "official" schematic symbol \$\endgroup\$– PlasmaHHCommented Jun 29, 2018 at 6:31
\$\begingroup\$ What's wrong with giving them an "official" symbol? \$\endgroup\$– Nike DattaniCommented Jun 29, 2018 at 8:20
2\$\begingroup\$ You would quickly run out of symbols when you gave everything one. It only makes sense for the most common things, not for a device that the majority of EEs never saw and probably even heard of. \$\endgroup\$– PlasmaHHCommented Jun 29, 2018 at 8:23
1\$\begingroup\$ in circles its often a lightbulb or a resistive load. NC pins are sometimes marked with Xs. In research I often see special sensors as just a box with an X (though its probably meant more as a box with diagonal lines). \$\endgroup\$– PlasmaHHCommented Jun 29, 2018 at 8:30
2\$\begingroup\$ @user1271772 Use any symbol you want, just make sure the target schematic reader understands what it is. You could place a blue circle inside a red hexagon, just as long as there is descriptive text that says "this is a Josephson Junction". I bet the references where you've seen an X tell you what the X means or make it obvious to infer from context. If you are writing an academic work, use the same symbol as the most relevant reference. \$\endgroup\$– Vicente CunhaCommented Jun 29, 2018 at 16:34
Show 4 more comments
1 Answer
It turns out there actually is a difference for Josephson junctions:
Source: https://qudev.phys.ethz.ch/content/courses/ASC04_SCqubits_Review.pdf
