-7
This question already has an answer here:
I have a simple question. I'm looking at using http://www.ti.com/lit/ds/symlink/cd4013b.pdf for my project and I need to be able to draw ~500ma from the 'Q' or '!Q' pin on the flipflop. How much current can I draw? I looked at the datasheet and couldn't find that information.
marked as duplicate by Dmitry Grigoryev, PeterJ, winny, Voltage Spike, DoxyLover Jul 6 '18 at 7:46
This question has been asked before and already has an answer. If those answers do not fully address your question, please ask a new question.
  • 5
    \$\begingroup\$ "How much can I draw from the output of a flip flop?" However much the datasheet says you can draw. This really should have been obvious. -1 for the dumb question. \$\endgroup\$ – Olin Lathrop Jun 29 '18 at 10:43
    \$\begingroup\$ You should also indicate what kind of load you have. If it is an inductive load (solenoid, motor, ...), there needs to be some protection. \$\endgroup\$ – dim Jun 29 '18 at 10:44
  • \$\begingroup\$ @ti_chris Looks like you'll need an amplifier then, or a switch that can handle that kind of current \$\endgroup\$ – Voltage Spike Jul 5 '18 at 18:58
Take a look at page 6 of the datasheet. The values for different V_o are in the range < 3..4 mA. So you have to take a nmost or pmos switch!
