I am currenty using the TS5MP646 http://www.ti.com/product/TS5MP646 . I need to build a 4:1 mux. I was wondering if I need to use 3 muxes, or can i just short the MIPI traces together and control it using OE pin on the mux?
1 Answer
If you look at the top of page 18 of the datasheet, you’ll see that /OE set high sets all the I/O pins to high-Z. Therefore, yes, at least in theory, you can wire-OR the outputs. Depending on the speed of the signals, you may have an issue with reflections from the stubs.
\$\begingroup\$ Would you recommend a 2 level design? \$\endgroup\$– loaderCommented Jun 30, 2018 at 20:43
