It might be easier to understand, if we quickly review how the RS-232 standard was originally used.
Note: All pin numbers below refer to the original 25-pin D connector; the numbering changed on the 9-pin connector used on later PCs.
Background
DTE = Data Terminal Equipment - in the old days, this would usually be a terminal or a printer, or equipment emulating those.
DCE = Data Communications Equipment - in the old days, this would usually be a modem or other WAN interface.
Pin 2 on the original 25-pin D connector (described in the standard as "Transmitted Data", "Circuit BA", "V24. number 103") should be data from the DTE to the DCE.
Pin 3 on the original 25-pin D connector (described in the standard as "Received Data", "Circuit BB", "V24. number 104") should be data from the DCE to the DTE.
This meant that the cable linking a terminal and a modem was "straight through" - pin 2 on a terminal (DTE) at one end of the cable where data originated, was connected to pin 2 on a modem (or similar) at the other end of the cable (DCE) where that data was received. The modem then sent that data out using the communications link, to whatever equipment was on the other end of that link.
Pin 3 "Received Data" was the data signal in the opposite direction - transmitted by the modem (DCE) on pin 3, and received by the terminal (DTE) on pin 3.
Therefore you can see that the labelling of what was Transmitted and what was Received, was from the point of view of the DTE (i.e. the terminal). This all made sense when the typical connections were between a DCE and a DTE.
However the pieces of equipment we are using these days (even when they don't use RS-232 and are instead using a TTL or other voltage UART protocol interface) are usually all effectively DTE (with one exception being modems). Connecting pin 2 (which is an output) on one piece of DTE, to pin 2 (another output) on another piece of equipment configured as DTE, makes no sense (and when using logic level signals, could even cause hardware damage). This is where the use of "crossed" or "null modem" (i.e. no modem) cables comes in.
Your question
I have been working with a device that uses RS232 communication to a PC. There has been some confusion as they have defined their TX and RX pins relative to the device. In their definitions they use to mean TX being the pin that sends data from the device. In my mind this should be labeled RX because it is the pin the computer receives on.
How should the pins be defined? Are they relative to each device or relative to the "controller"?
From the above background info, you can see that their labelling is correct if their device is acting as DTE (which most are, unless it's a modem or other WAN interface). On a piece of DTE, the pin labelled "Transmitted Data" (pin 2 on the 25 pin connector) does send data. (And, as explained above, on a piece of DCE (e.g. a modem) the pin known as "Transmitted Data" (pin 2 on its 25 pin connector) is actually an input, which receives the signal from the DTE.)
The PC's serial port will also be configured as DTE (unless it has a very unusual serial port - that won't apply here, as you would know if it did apply).
Therefore you are connecting DTE device (this device you've mentioned) to DTE device (the PC) i.e. there is no DCE in "RS-232 terminology, i.e. no modem, and the "null modem" or "crossed" RS-232 wiring will be needed. Whichever pin is RS-232 "Transmitted Data" (probably the one you mention they have labelled as TX) on this DTE device, which will be an output, will need to be connected to the RS-232 "Received Data" pin on your PC (also a DTE device), which is an input (and obviously vice versa for data transfer in the other direction).
Although this doesn't seem to apply to you, I'll just add: To make life more complicated, some manufacturers try to "help" by effectively labelling their DTE equipment as if it was a piece of DCE. They mark their data input pin as Tx so that user just connects "Tx" from the external device (which, if it's DTE, will be the data output from there) to the pin marked "Tx" on their equipment (which they know is an input). Thereby allowing them to say "just connect Tx on your device to Tx on our equipment". They think they are trying to help, but such labelling often just adds to the confusion.
As Dan Mills mentioned in a comment, many of us who grew up with RS-232, spent happy hours having to connect various equipment with slightly different RS-232 implementations, using the "breakout boxes" which he described. These breakout boxes have LEDs, which show which signals are being actively driven (this quickly allows you to see if the equipment is configured as DTE or DCE: Is pin 2 driven on that equipment? Yes = it's DTE) and have places where short jumper cables can be used to link the various connector pins.
