Hey I'm trying to do blinking led using interrupts on 16 bit timer. My atmega model is Atmega168A. Chip clock rate is 12Mhz.
Here is my code:
#include <avr/io.h>
#include <avr/interrupt.h>
ISR(TIMER1_COMPA_vect)
    PORTC ^= (1 << PC5);
int main()
    DDRC |= (1 << PC5);
    PORTC |= (1 << PC5); //led on
    sei();
    TIMSK1 |= (1 <<  OCIE1A); // cmp interruupt enable
    TCCR1B |= (1 << CS12) | (1 << CS10); //prescalser 64
    OCR1A = 11718; // value to compare
    TCCR1A |= (1 << WGM12); // set ctc mode
    while(1)
    return 0;
When the program startup led turn on. After compare match it should turn off. And it works, but with one strange problem.
If I change OCR1A, only the first peroid of time before led on and off changes.
When I set OCR1A e.g 0x100 the led turns off very quickly.
When I set OCR1A e.g 0xfffa the led turns off slowly.
But only the first state change.
Another led blinks do not take over about changes of OCR1A.
Whats wrong?
Do I need reset some flags or something like this?
  • \$\begingroup\$ You're assuming the timer resets to zero when it reaches the compare value. It doesn't. \$\endgroup\$
    – brhans
    Jul 2, 2018 at 22:48
  • \$\begingroup\$ @brahans Hmmm I added TCNT1 = 0x00 in ISR and it works. But why? Does the TCNT1 shouldn't be cleared automaticly/ As the doc says: "The counter value (TCNT1) increases until a compare match occurs with either OCR1A or ICR1, and then TCNT1 is cleared." \$\endgroup\$
    – bielu000
    Jul 3, 2018 at 4:06
You did not set CTC mode, WGM12 is in TCCR1B
