I'm trying to create my own circuit around this schematic. Its from a Waveshare 1,54inch E-paper display. I want to create my own board for this display, but I'm confused about what MOSFET this circuit uses.
It clearly lists that a Si1304BDL from Vishay Siliconix is used which is a N-channel enhancement mode MOSFET, but the symbol in the circuit diagram specifies a N-channel depletion mode MOSFET.
Here is an image of the MOSFET and the part number lines up with that of the datasheet.
MOSFET on Waveshare E-paper development board
I'm pretty sure it's a N-channel enhancement mode MOSFET, but I just want to be sure.
Thanks for your time!
    \$\begingroup\$ Very likely they just drew the circuit diagram wrong. It's much less likely they got the part number wrong, while the wrong symbol used can be just sloppiness/carelessness. \$\endgroup\$
    – anrieff
    Jul 3, 2018 at 21:13
  • \$\begingroup\$ The symbol for MOSFETs is a bit of a strange one. While there are strict standards saying how to make it and what it means, people butcher it all the times - sometimes with more valid reasons than others. Seeing people draw the ''depletion mode'' symbol for enhancement mode is something I see a lot, and many don't even realize there is a difference. \$\endgroup\$
    – Joren Vaes
    Jul 4, 2018 at 5:33
You can use a 'DMN3067LW' as replacement for the obsolete SI1304. It works fine on our selfmade boards.
Somebody made an error in choosing the library symbol for an old obsolete part.
