Today I was trying to measure the rectified SMPS incoming power supply ( 315VDC) using a tektronix TDS 3932C oscilloscope with P6139A probe. Every time the ground-probe touches the ground of the supply, the power supply rectifier diode is getting damaged. I assumed it may be related to earth fault current, but both equipment supplies are properly earthed.
I need some advice here.
Eqpt :Tektronix TDS 3932C Digital Phosphor Oscilloscope 300 MHz Probe used: P6139A , 500MHz, 8 pF ,10 MOhms, 10x
Edited I want to check the pwm controller IC O/p waveform with the oscilloscope, the Vcc of the IC itself is tapped from the rectifier supply, and I am unable to use the oscilloscope.
  • \$\begingroup\$ @Tony why bother? You were able to field an answer of some sort, and another answer even solved the issue. \$\endgroup\$ – W5VO Jul 5 '18 at 2:41
  • \$\begingroup\$ Do you really “some sort” is accurate?? everyone with a scope can do what I said. But few have the active probes HV $$$& \$\endgroup\$ – Tony Stewart Sunnyskyguy EE75 Jul 5 '18 at 3:13
You cannot connect oscilloscope ground to anything that is not at mains earth potential.
You will get the following short circuit through your oscilloscope:
I recommend this EEVblog episode:
EEVblog #279 - How NOT To Blow Up Your Oscilloscope!
(since you are lucky the diode failed first)
I must add that measuring on these live circuits is dangerous. You are supposed to use an active high voltage differential probe. A Tektronix P5200A for example.
There are also many other solutions to evade this problem, but since there are many safety caveats on these methods, I will not list them.
| improve this answer | |
    \$\begingroup\$ While it is clear what you mean by "You cannot connect oscilloscope ground to anything that is not at mains earth potential", that sentence is nonetheless false in general. If a circuit is floating (like a portable battery operated circuit), I can connect the scope ground anywhere I want. Just nitpicking. \$\endgroup\$ – Sredni Vashtar Jul 4 '18 at 15:18
  • \$\begingroup\$ @SredniVashtar excellent point. However, I’m not sure how to rephrase the sentence. \$\endgroup\$ – Jeroen3 Jul 4 '18 at 18:05
  • \$\begingroup\$ I would add "when the DUT is connected to earth..." at the beginning of your sentence. As I said, it is clear from context that you were right, but some rookie might take that to face value and unnecessarily ground floating circuits. \$\endgroup\$ – Sredni Vashtar Jul 4 '18 at 18:11
It is best practice to use a plastic cap >> probe capacitance in series with earth grounded probe leads then use two probes in differential mode on non-isolated DC supplies using 100:1 or 10:1 probes and ensure output is less than probe Vmax rating (e.g. 250V).
This avoids the diode V- short circuit loop current from earth bonded neutral to diode to V- to scope probe earth bond to AC input or similar scenario of non-isolated DC outputs.
  • \$\begingroup\$ Thanks. As mentioned I am using a capacitive probe 10x but the problem prevails. \$\endgroup\$ – seccpur Jul 4 '18 at 16:04
  • \$\begingroup\$ cap location needed on ground \$\endgroup\$ – Tony Stewart Sunnyskyguy EE75 Jul 4 '18 at 16:16
