Hello, i'm at a complete loss, have never came across that type of a ribbon cable, could anyone point me in the right direction as to the nature of the "bridge" between traces there. Cheers
4\$\begingroup\$ It's a Flexible PCB rather than a cable. \$\endgroup\$– Eugene Sh.Jul 4, 2018 at 19:07
\$\begingroup\$ The photo isn't good enough. Is the white thing a component or an earthing pad reinforcement that will be grounded on the equipment chassis by a screw through the flexible PCB? \$\endgroup\$– TransistorJul 4, 2018 at 19:09
\$\begingroup\$ I've updated the photo, and no it's not meant to be attached to the ground. \$\endgroup\$– DooMbie McDangersonJul 4, 2018 at 19:21
3\$\begingroup\$ It looks like it can be shorted or cut to configure something. \$\endgroup\$– Eugene Sh.Jul 4, 2018 at 19:25
6\$\begingroup\$ Again, it's a special pad to configure the PCB. It can be either shorted with a solder blob or cut apart. Unfortunately don't know the name of this, but it's rather common. \$\endgroup\$– Eugene Sh.Jul 4, 2018 at 19:44
1 Answer
One example why we use something similar:
We have a display which we use to connect to our board. The display comes with a flex foil. We also have a second source for this display from a second vendor. To identify the display vendor type we ask second vendor to short two traces. The flex foil as such is supplied by third party to both LCD vendors without bridging.
The board can easily identify the type of the display connected and load appropriate settings for the display.
