I've recently started trying to reverse engineer my old car's ECU (2001 Holden Jackaroo/Isuzu Trooper with a 3.0L diesel 4jx1 engine), purely as a learning experience. I've managed to identify and dump the contents of the EEPROM on the board (AM29F200BT). You may have to bear with me as my knowledge in this department is very basic.
As I understand it, it will make it easier to reverse engineer the program stored on the EEPROM, if I manage to identify the main microprocessor and the code it uses. However I'm having trouble identifying the main microprocessor on the board. I've tried googling the numbers with no success.
Has anyone seen one of these before or can anyone point me in the right direction of working out which family of microprocessors it belongs to?
Thanks in advance.
  • \$\begingroup\$ I appreciate that you're a beginner. Reverse-engineering ECUs is a specialist area, and while I'm not an expert, I've got some concerns about some details & assumptions in the question. (a) You mention "eprom" several times. Are you sure it's an EPROM, and not an EEPROM? Since you've read it already, please give its part number. (b) Why do you believe that the "eprom" contains the program code for this ECU? || Although you've just asked an identification type of question, I'm not sure that "microprocessor" (probably actually MCU) identification is going to help you, realistically :-( \$\endgroup\$ – SamGibson Jul 5 '18 at 2:13
  • \$\begingroup\$ Thanks for your response. Any advice i can get is greatly appreciated. I do believe it is indeed an eeprom(though its been a few weeks since i looked at it.) I've updated the original post to include the eeprom ID number. \$\endgroup\$ – Rob142 Jul 5 '18 at 2:18
  • \$\begingroup\$ It would be very helpful to disclose your "old car" make and model, as well as year of ECU production (from some IC labels for example). There might be car enthusiast groups who might have full information about your ECU \$\endgroup\$ – Ale..chenski Jul 5 '18 at 2:18
  • \$\begingroup\$ I've included the car make and model and engine number, though i cannot find any information on when exactly the ECU was manufactured. \$\endgroup\$ – Rob142 Jul 5 '18 at 2:27
  • \$\begingroup\$ Saw a post recently of a guy reviewing the new Tesla, right down to identifying chipsets. As you have found, automakers are not opensource orientated. I've got a feeling even if you stripped the epoxy coating, chip numbers will not be legible/visible. good luck. \$\endgroup\$ – aspiringGuru Jul 5 '18 at 3:07
It is very likely a Nippon Denso re-branded Motorola-mastered MCU MC68HC16 series, in distinctive 132-pin PQFP package, possibly MC68HC916R1, but might have custom modifications.
See how-to-hack-the-ecu-of-isuzu-trucks-from-japan, Link2.
  • \$\begingroup\$ Thank you for your helpful responses. I had actually stumbled across those links before, though with my limited knowledge couldnt put 2 and 2 together. Much appreciated. \$\endgroup\$ – Rob142 Jul 5 '18 at 4:24
  • \$\begingroup\$ So after a bit more research and tinkering. The mcu seems to be a closer match to the mc6833x family. \$\endgroup\$ – Rob142 Jul 9 '18 at 2:20
