I would regard papers like this with great scepticism.
First of all, the polynomials listed in that paper are apparently the "reversed reciprocal" of the actual standardized polynomials. They don't explain why - and this is really weird. The polynomial for CRC-16-CCITT is for example 0x1021, or if you will x^16 + x^12 + x^5 + 1. Apparently Wikipedia makes some effort into trying to make sense of this particular paper.
The polynomials were designed to remind as little of the most probable error pattern of the intended application. While the whole idea of Hamming Distance as some sort of ideal in data communication, is often taken out of the blue. To quote the paper:
For embedded
networks, the property of interest is usually the
Hamming Distance (HD), which is the minimum possible
number of bit inversions that must be injected into a message
to create an error that is undetectable by that message's
CRC-based Frame Check Sequence.
This is already making a whole lot of weird assumptions, such as that generic bit inversions are the most probable errors. They base the whole paper on this assumption.
But in a whole lot of cases, this only holds true when a low voltage bit gets turned into a high voltage bit by EMI - the other way around is far less likely. So if you come up with some theoretical test where you flip random bits in a generic data package, then ponder about Hamming Distance from there, you have already gone wrong and left scientific methods behind.
In order to make any sense of such assumptions, we must define the communication media. For example they mention the polynomial of CAN, which is a differential signal. When an error occurs from EMI, the chance of both lines flipping is non-existent and most of the error detection lies on the hardware level, not in the CRC. In fact CAN has such good error detection on the hardware level - sampling every bit carefully, that the CRC is mostly there for show.
And of course the probable error patterns on a CAN bus will be very different from error patterns in other applications. Take for example flash memory, where the main error-causing culprit is data retention over time, or possibly exceeding the number of write cycles - not EMI.
Therefore, to boldly claim that a polynomial with a particular "Hamming weight" is more/less suitable, without taking any specific application in account, is unscientific hogwash.
