I have the following circuit:
I am using a motor from an electric bike, as a generator and I am rotating it using a drill, to test its regenerative properties. The energy generated is consumed by R1. The current flowing through the circuit is controlled by a low-side N-MOS switch, using the STP55NF06L N-Mosfet. Its gate is driven by a PWM signal (at 500Hz) and an ICL7667 Mosfet driver.
I am using both a multimeter and the attopilot current sensor 90A version.
The output of the current sensor is driven to an AnalogToDigital port of my microcontroller. The problem is that the current readings I get from the sensor, are not steady and are changing rapidly, while the multimeter shows a nice, steady current value.
I decided to check the output of the current sensor using an osciloscope. With the N-MOSFET duty cycle set to 60%, and a current of around 1A (as measured from the multimeter), these were the results:
This picture has a 1V/div scale: enter image description here
This picture has a 500mV/div scale: enter image description here
How can I filter the above noisy signal to get a nice current reading from the sensor, like the one of the multimeter, that seems to be the mean value of the current flowing through the circuit?
    \$\begingroup\$ Have you considered low-pass filtering the output of the current sensor? \$\endgroup\$ – Sven B Jul 5 '18 at 11:27
    \$\begingroup\$ A drill near an oscilloscope? That's like trying to hear someone whispering near a waterfall. Low pass filtering, as suggested by Swen, is a possible solution. I wonder if there is a way to shield the RFI by operating the drill inside a thick metal box. Also, how did you probe the circuit? Ground spring or dreadful antenna ground loop? A differential pre-amplifier might be helpful too. \$\endgroup\$ – Sredni Vashtar Jul 5 '18 at 11:47
  • \$\begingroup\$ It looks like you may have some inductive component behavior (the generator). You might try putting a zener diode across the M1 to release energy from any inductive components. \$\endgroup\$ – Jaden Jul 5 '18 at 13:32
  • \$\begingroup\$ Unfortunately, I have little experience in filters. I have tried some simple low pass filters, unsuccessfully. Any detailed advice on how to calculate and choose the correct filter for the above case, will be greatly appreciated. \$\endgroup\$ – NickG Jul 7 '18 at 22:53
Seems like you are trying to filter the digital value as stored on your microcontroller. I would implement a moving average on the value. It's easier than filtering the signal through an analog circuit..
Here is someone who has implemented a moving average in C. Just remember to keep length of the average short enough.
|improve this answer|||||
  • \$\begingroup\$ If ADC has low enough sampling rate, it won't even see those spike. \$\endgroup\$ – Long Pham Jul 5 '18 at 12:59
    \$\begingroup\$ ADC might take the sample DURING the spike. \$\endgroup\$ – analogsystemsrf Jul 6 '18 at 3:40
  • \$\begingroup\$ I have tried some "software filters", but as mentioned above, the sampling does often occur during a spike. \$\endgroup\$ – NickG Jul 7 '18 at 22:54
