I have a high impedance differential sensor (stable 600k impedance Rth, 10mV signal, Fout=1kHz). I need to amplify this signal to about 1V (40dB gain). Due to layout/system constraints only the TLV9061 OpAmp stage can be used. Any suggestions on what topology would enable this? The problem I run into is that any difference amplifier or transimpedence amplifier needs feedback resistors that are unreasonably high (10s or 100s of Megohm) for a real world implementation.
I was looking into T-Network solutions as in this thread but it seems they suffer from high current noise.
Looking for any advice on other topologies to explore or methods to consider. Thanks!
  • \$\begingroup\$ (1) What's the nature of the sensor? (2) Is it connected through a cable? Or, is it mounted on the same PCB as the amplifier? (3) Is using an instrumentation amplifier an option for you? If not, why not? \$\endgroup\$ – Nick Alexeev Jul 5 '18 at 20:52
  • \$\begingroup\$ Sample rate or bandwidth? Is there a reason you cannot use an integrator? The (-) terminal of your opamp may need a guard ring. \$\endgroup\$ – jonk Jul 5 '18 at 21:00
  • \$\begingroup\$ There are ICs which pack 4 OpAmps into one small footprint, including feedback resistors. So the layout constraints can't be an excuse. Any so-called "instrumental amplifiers" should do the job, especially at 1 kHz range. \$\endgroup\$ – Ale..chenski Jul 5 '18 at 21:52
  • \$\begingroup\$ Single supply? Needs Vcc/2 ref not 0V . Long cable? Needs better CM balanced impedance on Vin(+) \$\endgroup\$ – Tony Stewart Sunnyskyguy EE75 Jul 5 '18 at 21:55
Why not just use the op-amp in non-inverting mode: -
The impedance it presents to the transducer is giga ohms and the feedback resistors are isolated from the transducer hence don't need to be mega ohms; they just need to have the correct ratio i.e. 99:1 to give 100x amplification.
For the TLV9061, be aware that if used in single supply rail applications the output won't quite get down to 0 volts.
  • \$\begingroup\$ Yes, I have come to this conclusion as well so focusing on this implementation. With dual rail supply. Thanks! \$\endgroup\$ – EasyOhm Jul 7 '18 at 7:45
If by "single op amp" you mean you can accept an 8-pin package, an AD621R in 8-pin SOIC will give you a gain of 100 with no external components and extremely high input impedance.
  • \$\begingroup\$ +1 Yep, modern silicon technology makes real wonders! \$\endgroup\$ – Ale..chenski Jul 5 '18 at 23:37
  • \$\begingroup\$ Sorry updated description due to size constraints have to use X2SON package \$\endgroup\$ – EasyOhm Jul 6 '18 at 6:08
