-1
I can't find SMD diode part no from Marking code,pls suggest if possible.enter image description here
  • \$\begingroup\$ thats because those codes generally say nothing much about it and are not meant for these identification purposes \$\endgroup\$
    – PlasmaHH
    Jul 9 '18 at 9:54
  • \$\begingroup\$ How big is it ? \$\endgroup\$ Jul 9 '18 at 11:55
  • \$\begingroup\$ Remove it from the board and try measuring the forward voltage drop \$\endgroup\$
    – User323693
    Jul 9 '18 at 17:41
  • \$\begingroup\$ sir it is SOD23 \$\endgroup\$ Jul 12 '18 at 4:00
  • \$\begingroup\$ @dim it is not necessary to mark this as a duplicate question, the link provided is related, but not a duplicate \$\endgroup\$
    – Voltage Spike
    Jul 17 '18 at 20:36
My guess is: CMOZ43L in SOD523, marking R1 found here: https://www.centralsemi.com/get_document.php?cmp=1&mergetype=pd&mergepath=pd&pdf_id=CMOZ2L4_SERIES.PDF
  • \$\begingroup\$ Sir it is SOD23 \$\endgroup\$ Jul 12 '18 at 4:04
