I'm creating a simple circuit and I need it to turn on when I press a button and stay on for the time that I choose on the timer (choose the time on a potentiometer, and it needs to go from like a few minutes to 3 hours). Eg. I choose 1 hour, press 'start', the light stays on for an hour and it turns off. The problem is that I can't find a timer that would work that way, can anyone help?
Ps: I don't want to use a microcontroller
Thanks
closed as off-topic by Eugene Sh., Voltage Spike, Dmitry Grigoryev, Dave Tweed Jul 14 '18 at 22:53
This question appears to be off-topic. The users who voted to close gave this specific reason:
If this question can be reworded to fit the rules in the help center, please edit the question.
    \$\begingroup\$ There are hundreds of such a timers in your local hardware/lighting store. \$\endgroup\$ – Eugene Sh. Jul 10 '18 at 14:52
    \$\begingroup\$ Pushbuttons? Hours? Definitely use a microcontroller. \$\endgroup\$ – Spehro Pefhany Jul 10 '18 at 15:22
Like an eggtimer? Most are digital now not pots, well because long analog delays are hard.
But if you want to make one , get a CD4060 and run clock with pot then choose any divider ratio, fixed or tap.
Then use a power FET to drive your load.
