given the values for \$\beta=5\$, for the Bessel of the first order:
\$ J_{0}(5)=-0.26, J_{1}(5)=0.34, J_{2}(5)=0.49...\$
in order to plot the amplitude spectrum of the FM wave, do you treat the negative numbers as absolute? The \$ J_{0}(5)\$ amplitude should be \$ |J_{0}(5)|\$ ?
If a frequency component has negative amplitude, it means 180 degrees phase shift for that component. If you only compare component strengths, it's ok to use absolute values.
