Background
We want to waterproof an electronic device and the specifications call for IP-65 protection. To this end, we have selected a sealed polycarbonate box to put the electronics in. The external connectors are reduced to a minimum and we use automotive IP-67 connectors. We tested a few prototypes and they cope with submersion. I'm closing on any remaining issues that may cause water damage in operation.
I'm worried that atmospheric air that gets trapped inside when the device is fully assembled might condense if cooled significantly. Especially if assembly is in mid-summer.
It seems that this problem is tackled in the industry by displacing ("backfilling") the air in the enclosure with nitrogen, helium and/or clean dry air. I don't have any experience with these, but they seem to be expensive operations that only make sense for medium- to large-scale production, when you have the equipment required.
Question
What production technique can be used for small-scale production (10-100s/month) to keep the humidity of the air low enough so that it doesn't condense?
Non-solutions
The device has a display which needs to be visible through the transparent box, so condensation-resistance is a must. Conformal coating alone won't suffice.
The device is battery-powered, so keeping the innards at elevated temperatures is also not an option.
I've read the excellent question about waterproof enclosures and unfortunately the "leaks more on the bottom than the top" strategy cannot be used here. Moreover, its answer specifically assumes "this is not meant for production" :)
  • 4
    \$\begingroup\$ Maybe a small amount of desiccant in the enclosure? \$\endgroup\$ Jul 10, 2018 at 22:21
    \$\begingroup\$ Do you have a service life requirement? Does the box get opened to periodically to replace the batteries? \$\endgroup\$
    – Jack B
  • \$\begingroup\$ If this isn't a situation where the customer needs to open the box and so you have control, I don't see a reason why dry nitrogen back-fill is an "expensive operation." What makes you think so? \$\endgroup\$
    – jonk
    Jul 10, 2018 at 22:23
    \$\begingroup\$ Or just use the low cost granular desiccant that comes in the small closed bags. These can be easily taped into desired places inside the enclosure using an inch square piece of double stick foam tape. Check on Amazon to see the wide range of sizes available and what kits of 100 or even 250 quantity cost. \$\endgroup\$ Jul 10, 2018 at 22:58
    \$\begingroup\$ Guys, please turn your comments into answers so that we can discuss comfortably on them \$\endgroup\$
    – anrieff
    Jul 10, 2018 at 23:27
Use silica desiccant
This is the stuff that often comes with clothes or moisture sensitive components in a little bag, often marked "do not eat" for some unfathomable reason. It's also used in some double glazing units to scavenge any moisture that does leak in, to avoid condensation.
Silica desiccant is cheap and is available in bulk, or pre-packaged in little permeable bags. You probably want the bag, and you can stick it somewhere out of the way inside the case with a dob of glue or double sided tape.
The desiccant will take up the moisture which is inside the box when it is sealed, and also any which leaks in over time. Eventually, it will saturate, and lose it's effectiveness, but if you use enough it will last a long time.
You can increase the life of the desiccant by minimising the moisture in the box when it is sealed. Warming the whole assembly, or blowing with warm dry air will help. Doing the final assembly in a small room with a dehumidifier running would be an option too. It will also last longer if the seal is good. Once the desiccant is saturated, it is possible to dry it out again in an oven, and it may be helpful to do so before putting it in the box, to make sure it hasn't got damp sitting on the shelf.
  • \$\begingroup\$ You could also vent it with a compressor air. These often dry air before compressing it. \$\endgroup\$
    – Jeroen3
    Jul 11, 2018 at 10:00
