I have an ADC sampling a downconverted RF signal at fs. I obtain N=2^15 samples of the RF input signal "fcarrier + fs/10".
The more I average, the more the entire noise floor shifts down (as expected, 10dB/dec) but also the phase noise skirt. I can average down to 100dB SNR (I didn't wait longer). For 1000 averages, the (zoomed) spectrum looks like this:
The phase noise skirt just moved down by 30dB as compared to the non-averaged version. This suggests I can average the phase noise out. But I would not expect it to be averaged out. According to http://www.bitsofbits.com/2015/07/07/signal-jitter-and-averaging/, the signal should be a cosine convolved with an exponential ("signal-leakage like") after infinite averages.
  • Can phase noise be reduced?
  • If yes, does can it be averaged out same as white noise? (This is what I observe above).
  • How does this fit into the link posted above?
  • Does it depend on the input signal? (sinusoid vs wideband)?
  • \$\begingroup\$ What sort of equipment gives enough resolution to read 4.761904761904762 MHz with that level of precision? \$\endgroup\$ – Transistor Jul 10 '18 at 22:32
  • \$\begingroup\$ As an engineer, numbers like 4.761904761904762 make me chuckle. \$\endgroup\$ – evildemonic Jul 10 '18 at 22:34
  • \$\begingroup\$ It just does not matter. Then no numbers. Numbers removed. \$\endgroup\$ – divB Jul 10 '18 at 22:37
  • \$\begingroup\$ @Transistor Answer: An extremely picky filter with the highest frigging Q-factor you've ever seen. Float value needs to be more specific. \$\endgroup\$ – KingDuken Jul 10 '18 at 23:08
  • \$\begingroup\$ If you have random noise, doesn’t an average of 2 = -3dB and 1000= -30dB in noise? \$\endgroup\$ – Tony Stewart Sunnyskyguy EE75 Jul 11 '18 at 0:30
Let us model additive noise, atop a sinusoidal carrier, as 2 small noise sources in quadrature.
We have this vector diagram
The inphase noise is AM: amplitude modulation noise.
The quadrature noise is PM: phase modulation, or phase noise or jitter.
Is there any specific reason why more samples, averaged together, would not produce a lower standard deviation?
By the way, what is the ADC/sampling_clock phase noise spectrum?
  • \$\begingroup\$ This answer does not really help me yet and does not answer the question (IMO) but maybe I don't understand it yet. There is oscillator noise (consisting on amp.&phase noise) but phase noise is by definition phase only (and let's not assume I/Q for simplicity but only consider one channel). As I hinted in my question, PN is not additive but multiplicative, hence I don't expect averaging to work. Furthermore, does it make a difference if the signal is purely sinusoidal or a complex modulated signal? \$\endgroup\$ – divB Aug 7 '18 at 7:53
  • \$\begingroup\$ If you show the noise as a centroid around the tip this would be clearer. \$\endgroup\$ – Scott Seidman Jun 22 at 16:34
